Originally posted by bugler777
Thanks for the reply.
Does any of this relate to the fact that if a violin string is vibrating at a certain frequency and then is made half as long by moving the finger half way up the finger board, the frequency of vibration will double sounding a pitch an octave higher than the original. And wouldn't it be true that only half as much string mass will be vibrating at the new frequency?
No. While it is generally true that when a guitarist frets the string, only the side he plucks has any substantial vibration, this is not always the case.
A string can vibrate in many different ways -- each way is called a "mode." A string's first mode of vibration, as I said, has one node at each end, and one antinode exactly in the middle. The second mode (also called the second harmonic) has three nodes (one at each end, one in the middle) and two antinodes (at l / 4 and 3 l / 4).
In a properly done experiment (where the node in the middle is supported properly), the entire string can vibrate. One half goes down while the other goes up. Obviously, the entire string is still vibrating, and therefore the mass is the same -- but now the frequency has doubled. This goes directly against what you are proposing.
Indeed, you can play harmonics on a guitar by striking an open string (to excite several modes, but mostly the fundamental mode) and then gently touching the string right in the middle, over the 12th fret. By gently touching the string, you are killing the fundamental-mode vibration, and keeping the second-mode vibration. When you remove your finger -- viola -- you have the entire string vibrating at twice its fundamental frequency. Once again, this goes directly against what you are proposing.
Let's look again at that last equation,
<br />
\nu = \frac{1}{\lambda} \sqrt{\frac{\tau}{\mu}}<br />
What you seem to be missing is this piece of wisdom: the frequency of the vibrating string does
not depend upon the mass of the entire string. Instead, it depends upon the
linear mass density, the mass per unit length. The mass of the entire string never enters the equation above.
It is true that halving the string's length doubles its frequency (if you halve \lambda, you double \nu), but it has nothing to do with half the string having half the mass. Instead, you've just decreased the wavelength by two, and therefore increased the frequency by two. The total mass just has nothing to do with it.
As I explained in my previous post, doubling the mass of the string (while keep its wavelength constant) only reduces its frequency by about 30%.
- Warren
