Relationship between stress and density
The discussion explores the possibility of calculating changes in density due to mechanical stress applied to an object. It is noted that while all materials are compressible, solids and liquids exhibit much lower compressibility compared to gases, making significant density changes unlikely under bending stress. The Clausius-Mossotti relation is mentioned in the context of stress-induced birefringence and its link to dielectric constants, suggesting a need for alternative approaches to relate stress and density. Additionally, the use of Hooke's law is proposed as a method to calculate density changes in linearly elastic solids under specific loading conditions. Overall, the consensus is that while density changes due to stress are minimal, there are theoretical frameworks to explore these relationships.
MarcGyongyosi
Hi everyone,
I am curious as to whether it is possible to calculate the difference in density due to applied (mechanical) stress on an object.
E.g.: apply a controlled force of, say, 50 N on a structure, calculate the mechanical stress in the object with sigma = M/I * z and then go on from there, using some kind of relationship between stress and density to figure out how density changes throughout the object...
Looking forward to an answer, if there is one ;)
Thank you very much!Marc
Welcome to PF
The compressibility of a substance is discussed here
Everything is compressible but solids and liquids are a lot lot less compressible than gases.
where?
HAha - click on the blue "here".
that link was not there when I first loaded the page.
In a nutshell, no, there is no relationship between bending stress and the change in density of an elastic structure.
I am curious as to what prompted this question in the first place.
Hi,
we are working on a problem involving stress-induced birefringence... since the dielectric constant of a substance can be put in relation with its density (Clausius-Mossotti relation) it would have been interesting to be able to link a "change in density" due to stress to a change in the dielectric constant... I guess, however, we'll have to look for another way!
But thank you very much!
Just a thought. As the compressibility of solids is so high, would it not be more likely that a dielectric material, when deformed by a force, would assume a shape which would maintain the density, ( i.e. virtually unchanged) as it changed shape? I am not into Materials Science really but it would seem a reasonable assumption.
(I pressed the 'go' button on my first post before I was ready)
Photoelasticity also uses birefringence of materials to show the distribution of stresses within the material as it is loaded.
See: http://en.wikipedia.org/wiki/Photoelasticity
I think the C-M formula involves the density of a material, not the change in density. Are you saying that the dielectric constant a material isn't a constant?
@SteamKing
given birefringence and from Maxwell's eqn. with \mu≈1 and εr=n2 I am trying to use the C-M formula to compute the refractive index given a volume change due to a force applied on the structure/object... I'll work on it and see if it fits the experimental data...
Thank you for your help!
Marc
Using the 3D tensorial form of Hooke's law involving the Young's modulus and the Poisson ratio, one can calculate the change in density of a linearly elastic solid material under prescribed loading.
