Relationship between Voltage and Current
Increasing voltage through a transformer reduces current, which minimizes power loss during transmission. The relationship between voltage, current, and resistance is clarified by understanding that power is held constant in power lines, making voltage and current inversely proportional. While higher voltage can lead to increased electron flow, the key to reducing losses lies in keeping current low, as losses are primarily due to I²R in the lines. Insulation losses are negligible compared to conduction losses, which is why power companies prefer high voltage and low current for efficiency. Future advancements like high-temperature superconductors may alter these dynamics, but current practices prioritize minimizing conduction losses.
Mastaan
P = VI . Now say I want to transfer power over long distance, i put it through the the transformer increase the voltage to decrease loss over the line, this is where I am confused.
So when u increase the voltage through the transformer, you decrease the current. Voltage is the potential difference between two points. Now if there is a more potential difference then before between 2 points shouldn't there be more electrons going through the wire. And thus increase the resistance in the wires and give more loss. Also what doesn't make sense is that the Current decreases as voltage goes up. But then if u look at the equation V = IR, if resistance is constant then as voltage goes up then current goes up?
This is contradicting each other, I am confused.
It depends what you are holding constant. If you hold power constant (which is virtually never the case), then V and I are inversely proportional. If you hold resistance constant (which is much more often the case, including power lines), then they are directly proportional.
In the case of power transmission, the power lines' resistances are almost constant, so much so that for learning purposes you can consider them that way.
Well I guess I am mixing up the resistance of the wire to the load. So there will be some power loss through the wires but why does increasing the voltage decrease the loss? Because I thought the more voltage u have the more current you have through a circuit. But I guess I can't compare it to a power grid circuit where the load is always changing. This is so hard to picture it in my head. This is also an alternating current so the voltage is swinging and the electron movement is also increasing and decreasing. Now it all makes sense. So increasing the Voltage RMS value through a transformer will all increase the amount of electrons flowing at peak value. Damn it I am still confused.
The power loss in the line is I2Rline...
so the idea is to keep current low to reduce lines losses...
The losses incurred in the t-line are as follows.
Insulation loss = V2Gline...
Conduction loss = I2Rline...
For typical t-lines, the conduction loss is many orders of magnitude greater than the insulation loss. By stepping the voltage up with transformers, the current is stepped down. The insulation loss increases but it is tiny to begin with. The conduction loss goes down greatly. That is why the power companies transmit the power at high voltage with low current. The losses are lower this way.
Some day, high temperature superconductors may be a reality & cheap. That might change things, but for now, this is how it's done.
Claude
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
  • · Replies 16 ·
  • · Replies 23 ·
  • · Replies 17 ·
  • · Replies 61 ·
