Relative Atomic Radii (Atoms and Ions)
The discussion revolves around determining the relative atomic sizes of neutral atoms and ions, focusing on comparisons such as Cl- versus S and Na versus Cl-. Participants explore the rules and guidelines that might apply to these comparisons, as well as the challenges involved in making such determinations.
  • Homework-related
  • Some participants suggest that for identical numbers of electrons, the atomic radius decreases with increasing nuclear charge, while for identical nuclear charge, the radius increases with more electrons.
  • Others argue that there are no strict rules that apply universally to all situations, emphasizing the need to consider electron configurations.
  • One participant notes that anions are generally much larger than their neutral counterparts, providing the example of the oxide ion being significantly larger than the oxygen atom.
  • A question is raised about whether negatively charged ions should be grouped at one end of a size ranking, with neutral atoms in the middle and positively charged ions at the other end, although some caution that this may not hold true in all cases.
  • Another participant mentions that the radius of atoms is an ill-defined property and that exact numbers may not be necessary for rough approximations.
  • There is a repeated emphasis on the need to check specific rules regarding the number of electrons and protons when comparing sizes.
Participants express differing views on the existence of universal rules for comparing atomic sizes, with some asserting that general trends exist while others highlight the complexity and variability of the topic. The discussion remains unresolved regarding the application of these rules to specific cases.
Limitations include the ambiguity in defining atomic radius and the potential variability in comparisons based on specific electron configurations and nuclear charges.
lafalfa
Hi,
How would you determine the relative atomic sizes of a neutral atom and an ion?
I can't figure this out. It can't be that all neutral atoms are always smaller than all ions can it?
For example, how would I determine if Cl- is smaller or larger than S?.
(The answer is that Cl- is larger than S).
Is there a rule that applies to all comparisons of neutral atoms and ions?
For example, how would I determine if Na is smaller or larger than Cl-?
Thank you very much!
Chemistry news on Phys.org
The only solid and strict rules here are that for identical number of electrons, radius goes down with increasing charge of nucleus, and for identical charge of nucleus, radius goes up with increasing number of electrons. When both change at the same time and in the same direction result is sometimes difficult to predict.
Lol, it's chemistry, of course there isn't a rule that applies to ALL situations. There are however guidelines that you can use to generalize (see Borek's post). You really have to look at the electron configuration of each ion/atom to be sure.
But then how would I conclude that Cl- is larger than S? I have to be able to conclude this somehow since I have this question for school.
Anions are always *much* larger than the neutral atom. (i think the oxide ion is twice the size of an oxygen atom) So, even though S is *slightly* larger than Cl... Cl- is *much* larger than Cl.
That's the best I can do.
So when asked to order atoms/ions in terms of their size, would I immediately put all the negatively charged ions at one end, all the neutral atoms in the middle, and then all the positively charged ions at the other end, regardless of their relative positions on the periodic table?
Well, I'm sure if you get far enough apart on the table (neutral cesium vs. fluoride ion) that won't always be the case, but mostly, yes.
I think.
Char. Limit said:
Ions are always *much* larger than the neutral atom.
Ions can have positive charge too, you know?
Anyway, original poster, the idea is that you learn the general trends seen on http://boomeria.org/chemlectures/textass2/table10-9.jpg" chart.
Apart from those overall general trends, the radius of atoms is an ill-defined property. There's no need to know the exact numbers, except perhaps as a rough approximation.
Check if one of the "rules" I have listed won't give an answer. Do they have the same number of electrons? Or perhaps do they have the same number of protons in nucleus?
As alxm already suggested - check radius of K+ vs K, or Mg2+ vs Mg.
methods
Oops, I'm making mistakes everywhere I go, it seems. Let me fix that to "anions".
9K
14K
