Relative Motion & Rotation of Axes of Reference
The discussion revolves around the concept of relative motion and the rotation of reference axes in the context of spacetime, as introduced in the works of Einstein and Minkowski. Participants explore the implications of representing velocities as four-component vectors and the associated challenges with units in relativistic physics.
  • One participant questions whether the velocity of an object relative to a stationary point can be described by a four-component vector with a magnitude of c, suggesting that the spatial components define the "observed spatial velocity."
  • Another participant confirms the initial query about the four-velocity and provides a link to a Wikipedia page for further reading.
  • A participant expresses confusion regarding the units involved in calculating component vectors, particularly when different units are used for spatial dimensions.
  • There is a discussion about the use of "natural" units in relativity, where c is set to 1, making velocities unitless and implying a relationship between units of distance and time.
  • Participants discuss the necessity of converting units before calculating resultant magnitudes and the implications for the time component of the four-velocity.
  • One participant seeks references for visual and mathematical representations of these concepts in a 3D universe with two space and one time dimension, but does not receive a satisfactory answer.
Participants generally agree on the need for unit consistency in calculations involving four-velocity and the implications of using natural units. However, there remains uncertainty regarding the specifics of unit conversions and the existence of a unitless value for c, leading to a lack of consensus on some points.
Participants express uncertainty about the implications of unit conversions and the relationship between distance and time units, indicating that these concepts may require further exploration and clarification.
This discussion may be useful for individuals interested in the foundations of relativity, the mathematical representation of motion in spacetime, and the challenges of unit consistency in physics.
Holystromboli
I'm still very early on in my reading, so forgive me if this question isn't coherent. In the "historical introduction" section of the 1920 University of Calcutta translation of the original papers of Einstein and Minkowski available via the MIT online archive, mention is made of the fact that "in the spacetime reality, relative motion is reduced to a rotation of the axes of reference," but no mathematical or graphical representation of this concept is given. Does this imply that the velocity (this isn't a good word for what I mean here but it's the best I could do:) ) of an object relative to an assumed stationary point can be described by a 4 component vector (3 space components and one time) with magnitude c such that the combined magnitude of the 3 spatial components defines the "observed spatial velocity" of the object?
Yes. See here:
http://en.wikipedia.org/wiki/Four-velocity
Wow. That is pretty awesome stuff. Thanks for the link. I read through it, but I'm still a bit confused. I took a lot of undergraduate level advanced math classes (impressive, I know :p ), but it's been a loonnngggg time. I can understand the need to delineate "proper time" from time as defined at the stationary observation point, but even with that in mind I'm struggling in my understanding of the units involved. Don't units matter when calculating the component vectors? If the component vector in spatial dimension x is given in in/min and y in m/s, you'd have to convert to common units before the resultant magnitude could be calculated correctly, right? How does this principle apply to the fourth component vector for time? If my assumption were correct, it would imply that there must be a fundamental relation between units of distance and time (e.g. the number of seconds in a meter) in order for us to be able to convert to common units, and this by extension would imply the existence of a unitless value for c, which I've never heard of. What am I missing? Or can we use the value of c itself to calculate an absolute number of seconds in a meter? Also, do you have a reference for a visual and mathematical representation of these concepts for a 3D universe containing 2 space and 1 time dimensions?
In the units used in the Wikipedia page, 4-velocity has the same units as ordinary velocity (see further comments below).
In "natural" units commonly used in relativity, in which ##c = 1## by definition, velocities (4-velocity and 3-velocity) have no units; they are unitless numbers. This amounts to using the same units for time and space (again, see further comments below).
Yes.
In ordinary units, you multiply it by ##c##. (In the case of 4-velocity, the time component is just ##c## times ##\gamma##, where ##\gamma = 1 / \sqrt{ 1 - v^2 / c^2 }## is the standard relativistic factor.)
Yes, there is.
No, it implies what you yourself say further on:
Yes, exactly: ##c## is just the conversion factor between ordinary distance units and ordinary time units. If you adopt the "natural" units I referred to above, in which ##c = 1##, you are simply adopting the same units for distance and time: for example, feet and nanoseconds (approximately), or meters and "light-meters", the time it takes light to travel 1 meter (about 3.3 nanoseconds), or years and light-years (the latter is often used in astronomy and cosmology).
Hahaha that's awesome! Thanks for the quick responses!
Was that a no? :)
Holystromboli said:
Was that a no?
Correct, sorry, I don't have any useful references handy for that.
  • · Replies 38 ·
  • · Replies 31 ·
  • · Replies 146 ·
12K
  • · Replies 53 ·
  • · Replies 45 ·
  • · Replies 21 ·
