memoguy
- 29
https://dl.dropbox.com/u/51681259/physics_diag.png
Object C & P are moving at the same constant velocity to the right, in the configuration of the image. The friction between object C and the ground is 0. Suddenly the friction increases to μ=0.9 between the ground and object C. This makes object C decelerate to a stop over 4m. At what velocity does object P impact the right internal side of object C. There is no friction between C & P.
d = 1m (distance between p right side and c internal right side)
μ = 0.9
s = 4m (stopping distance)
I can fine object c's initial velocity by combining a couple of formulas:
F_net=ma
F_friction=μmg
v^2=u^2+2as
I find the initial velocity of C & P as being 8.4m/s.
Then I can find the acceleration of C, relative to the ground, after the increase in fiction which turns out to be:
-8.82m/s/s
And that means that relative to C, P accelerates forward at 8.82m/s/s. <IS THAT CORRECT??>
Then I take p's relative acceleration and the initial velocity and put them through v^2=u^2+2as
and find:
v^2=8.4^2+(2*8.82*4)
v=9.39
So my answer is that P impacts C at 9.39 m/s. Is this even close to correct?
