Relativistic centrifugal force
In summary: I think they are safe.)In summary, there are several different rotating reference frames available, each with their own answer to the question of what the force at a point on the rim of a rotating disc is. Without considering relativity, centrifugal force is mv²/r.
Alan McIntire
30
TL;DR Summary
I assume there should be a correction for relativity in measuring centrifugal force from the point of view of a particle on the rim of a rotating disc. Is the correction
1/√(1-v²/c²) , or is there an additional correction for acceleration in a perpendicular direction?
I first thought of this problem when I came across the "Ehrenfest Paradox", and realized that as velocity approaches c, the measured force must diverge to infinity as the velocity approaches c.
Unfortunately, this question does not have a unique answer. There are several different rotating reference frames available, each with their own answer to the question. Which would you prefer?
Here is a list that describes several different ones you might consider.
https://www.amherst.edu/media/view/10267/original/reden05.pdf
The one defined by 2.17 is probably the best “traditional” one to use, but 2.19 has some nice mathematical properties.
Likes Alan McIntire and Nugatory
Thanks for that reference. It's just what I was looking for. I realize that clocks on a rotating disc cannot be synchronized, but the force at a point on the rim should have a unique answer. Either the force of a given weight tied to a string with a given tensile strength on the rotating rim is great enough to break or it isn't.
The whole point of the Ehrenfest Paradox was that “rigid bodies” cannot actually be completely rigid, but stretch and shrink under various forces. If the forces are great enough, as in high acceleration or angular acceleration, the disc cannot hold its shape- it’s going to break apart no mater HOW "indi
structable" the materal.
Likes Dale
Alan McIntire said:
Summary: Without considering relativity, centrifugal force is mv²/r.
The relativistic force needed to cause acceleration transverse to the motion of a particle is gamma times the Newtonian force. So that would be the coordinate centripetal force ##F=\gamma mv²/r##.
When such coordinate force is applied to a particle that is moving to the perpendicular direction to the force, it feels like a gamma times larger force for the particle.
So therefore the particle feels a force ##F'=\gamma^2 mv²/r##I admit that that was not a calculation done in a rotating frame.
We know that a particle on the rim observes gamma times larger angular velocity of fixed stars than a particle at the center observes. So it seems we could quite easily derive an equation that uses that angular velocity of fixed stars observed by a particle. That equation we could then maybe call "centrifugal force in a rotating frame".
Likes Ibix
jartsa said:
So therefore the particle feels a force ##F′=\gamma^2mv^2/r##
Just to be clear (I'm not sure if your next line was intended to convey this), ##\gamma##, ##v## and ##r## in this formula are those measured in the rest frame of the center of rotation.
This is where I think you need to look at the PhD thesis Dale linked - I suspect "the angular velocity of the distant stars" depends on your simultaneity convention.
More precisely, there can't be any such thing as "rigid motion" of a body except in a few very special cases. Spinning up a non-rotating disc to make it rotating is not one of those special cases, so it is impossible for such a disc to remain rigid and retain its exact non-rotating shape after it is rotating.
The more precise version of the above goes by the name of "Born rigidity", and the special cases where it can be realized are classified by the Herglotz-Noether theorem. The Wikipedia article on Born rigidity gives a brief overview:
https://en.wikipedia.org/wiki/Born_rigidity
I'm a little leery of the procedure undertaken in section 2 of this thesis, because it is deriving "spacetime metrics" without verifying that the different coordinate charts being used are all valid. In particular, metric 2.19 is using a discontinuous definition of "time", which I suspect might lead to a discontinuity in the coordinates that is not being taken into account.
(The other two metrics, 2.15 and 2.17, are using Born coordinates as they are usually defined, and Born coordinates with the time coordinate rescaled. So 2.15 is using a known valid chart, and 2.17's chart is probably valid.)
Also, the "problem" stated in section 1.7, that the metric tensor of the "space" of the rotating disk appears to be non-Euclidean, whereas spacelike slices of constant time in the lab frame are Euclidean, does not have a "solution", if by that is meant an actual set of non-Euclidean spacelike slices "cut" out of the spacetime in some way. There aren't any. The spatial geometry derived in section 1 for the disk does not correspond to any spacelike slice.
Yes, it does. More precisely, the proper acceleration of an observer rotating with the disk at any point is an invariant (since proper acceleration always is). The Wikipedia page on Born coordinates that I linked to computes the proper acceleration in both lab frame coordinates (the "Langevin observers" section) and Born coordinates (corresponding to metric 2.15 in the thesis @Dale linked to), and it can be seen that they are the same.
It is definitely discontinuous, but I think it is pretty clearly identified and taken into account.
However, it is not problematic to remove that discontinuity from the chart and cover the manifold in two such charts if needed.
That metric is actually the one I find most interesting here.
But doing that eliminates the possibility of describing the "space" of the disk as a whole at some instant of time using a spacelike slice of this metric, since the discontinuity means there is no way of covering the entire "space" with a single chart. This is a consequence of the fact that the "space" in question is a quotient space and does not correspond to any spacelike slice in the spacetime.
Yes, completely agreed. I usually don’t care about that, so the simplicity of the metric is appealing.
The reason that I said there was no unique answer to your question is because your question specifically asked about the centrifugal force. The centrifugal force is a fictitious force, in the language of tensors it is one of the Christoffel symbols. The fictitious forces / Christoffel symbols depend on your choice of coordinates.
Now, the measured tension in a given string attached to a given weight is indeed unique. As you say, the observable fact of whether or not it breaks cannot be frame dependent, but that is not the same as the centrifugal force. The difference is mainly due to different definitions of time in the different coordinate systems.
There are better (more rigorous) derivations, but this is, indeed, the magnitude of 4-force felt by a 'particle' of the disc with constant angular velocity per the lab frame. As @Ibix noted, all quantities as measured in the lab frame, but this resulting magnitude is invariant.
PAllen said:
There are better (more rigorous) derivations, but this is, indeed, the magnitude of 4-force felt by a 'particle' of the disc with constant angular velocity per the lab frame. As @Ibix noted, all quantities as mentioned in the lab frame, but this resulting magnitude is invariant.
Agreed, or, to put it another way, ##\gamma^2 v²/r## is the proper acceleration of a point on the disk, and is the value measured by an accelerometer attached to that point.
I find it intriguing that a simple spinning disk can appear to defy analysis whereas a black hole (even a spinning one) is described fairly simply!
As I understand it, we cannot use SR to analyze the spinning disk because it is not globally flat, but what is it precisely that prevents a solution to einstein's equations (I guess in 2+1D, there is plenty of symmetry)?
Perhaps we do not need the full mechanism of GR (stress-energy tensor), or perhaps it is inescapable owing to the presence of curvature. Is there any concept of GR kinematics (I hesitated to even ask that last part!)?
A spinning disk does not defy analysis. There are in fact multiple ways to analyze a spinning disk. The difference is that by the time people get to GR they know that the coordinates have no physical significance and they are used to clearly specifying the coordinates without expecting clocks and rulers to measure coordinate times and distances. People analyzing the spinning disk often are trying to do so using Einstein synchronization, but nobody analyzing a Kerr black hole tries that.
The spacetime is globally flat so SR is all that is needed. There is no need to find any solution to the Einstein field equations other than the trivial flat spacetime solution of SR.
What you do want to use is tensors and differential geometry. That is not GR, but it is a mathematical tool that is heavily used by GR.
It's not enormously problematic if you use tensor tools. It's just that there isn't just one obvious answer for how to set up a coordinate system, and naive approaches based on adapting standard inertial frame SR lead directly to elephant traps.
Spacetime remains flat. But it's very easy to produce non-flat spatial slices, fail to realize you've done it, and end up in a mess - as has been demonstrated fairly comprehensively over the last month or so.
I was careful to say "appear" ;)
So the global metric for the spinning disk is Minkowski? I need to get my head round that!
I think I'm too used to hearing that the circumference "contracts" whilst the radius does not. To me that points to a "conical" (ish) spacetime. [Thinks:] But then that is flat apart from the point . . . ow my head.
Centrifugal forces and the "Ehrenfest Paradox" are different issues. Even if you perfectly balance the centrifugal forces with some externally applied centripetal forces, a rigid disc will still break, when you try to spin it up.
The metric is independent of any coordinate system(*). It is an invariant feature of the space-time. The space-time is flat. The motion of the disk and the motion of any coordinate system that one might want to attach to the disk are irrelevant.
(*) If you want to write down the metric you will likely want to do so using a coordinate system. The representation of a metric using a particular coordinate system will depend on the coordinate system. [And here we reach the limit of my knowledge of the subject].
So it can be Minkowski because it is flat, but you would need to do coordinate transormations in order to represent various observers, eg. someone riding on the disk at a certain radius (we are after all discussing centrifugal forces). Is that any closer; I don't recall encountering any such metric, so perhaps it is not even useful?
I suppose even defining rotational speed is a problem where there is no rigidity!
The spacetime containing the spinning disk is Minkowski; that manifold uses the Minkwoski metric. That is, every event on the worldlines of every point that makes up the disk is an event in Minkowski spacetime; collectively these worldlines form a worldtube in that spacetime. However, we can choose subsets of these events to form submanifolds that are not Minkowski (rather as the non-Euclidean surface of a two-sphere can be embedded in Euclidean three-space). So what's going on here is that there is no spacelike slice through that worldtube that is both Euclidean and corresponds to our intuitive notion of "the surface of the disk".
Actually, forget the Euclidean part. There is no spacelike slice (at all) through the world tube that corresponds to intuitive notions of "surface of the disk". Specifically, no spacelike slice that is a local time slice for every particle of the disk surface. Mathematically, the stationary rotating congruence has no hypersuface orthogonal spatial slices at all.
Likes PeterDonis and Nugatory
In the Rindler spacetime I am used to the proper time of an extended accelerated object running at different rates along the object (i.e. slower at the rear where the acceleration is greatest). Are you just saying that proper time passes at different rates with radius? It sounds like more than that to be honest but I had to ask.
I am saying more. Nearby clocks slowly diverging form each other is not the issue. Each world line of a congruence has a local notion of space around it evolving in time. That space is the 3 surface 4 orthogonal to their world line. For the Rindler congruence, you can knit these together to represent the whole body at a moment of time. In the Rindler case, different particles will label the time of consecutive moments of the body as a whole differently, but all agree on the set of events that make up a moment for the body as a whole, by knitting together their local space.
For the stationary rotating congruence, there is no way to do this at all. Any set of events you try to say is a moment of the disk as a whole will fail to represent a locally defined momentary space for some particles of the disk.
This is what is captured in the notion of hypersurface othogonality.
Likes Nugatory
Yes. The metric is a tensor, so it is by design independent of the coordinate system. However, you typically represent a tensor by its components in some basis (usually a coordinate basis). As you change your coordinates you change your coordinate basis vectors and therefore you change the components of the tensor.
So the metric tensor is the Minkowski metric, but the components will not be the same as the components in a standard inertial frame.
As far as hypersurface orthagonality goes, look at the diagram below. I didn't draw it, the original was drawin by another PF poster, Ibix.
Ignoring the fine points of Lorentzian geometry for now, try to imagine a line that is everywhere orthogonal to the slanted, green, vertical lines on the diagram. You can find segments of such a curve, but it isn't a closed curve. The vertical lines represent the notion of "time" on a 2 space + 1 time space-time diagram on a rotating hoop, and the curve that we asked for, one that is orthogonal to all the lines, would represent the "hypersurface" that's orthogonal to time. The problem is that the curves are not closed.
The problem becomes more acute if you consider a cylinder rather than a hoop, but it's hard to draw the needed lines clearly of this situation on a 2d piece of paper.
That's basically enough to get the idea. The hard part really is getting people to draw space-time diagrams, or to get them to look at and interpret ones that others have already drawn. While I recognize the difficutly, I don't know what to do about it .
Likes m4r35n357 and Ibix
I was going to repost this myself last night, but got interrupted and forgot. The slanted lines are actually cyan. In the left hand image their bottom ends are joined by a green line, which is the line you are talking about. It is everywhere orthogonal to the cyan lines, but does not close because it forms a helix.
I can post a zoomed in view of the relevant part of the diagram later if that would be helpful. Currently on my phone and I don't have the necessary software or files.
Likes m4r35n357
  • #31
One thing to add to the beautiful posts above, that @pervect mentioned in passing, is how much worse it gets going from a ring to a disc. In the ring case, there is continuous curve orthogonal to all congruence lines - it is unfortunately an infinitely long spacelike spiral, parts of which are in the future of others; that is, it intersects each world line an infinite number of times. However, the anomalies are all global; over reasonable finite lengths, you see no problem. Locally, this spiral is everywhere orthogonal to the rotating ring congruence.
Once you go to a disc, the failure becomes local. You cannot find any finite area slice orthogonal to all the intersected congruence lines. This comes about because while the disc congruence has no expansion or shear, it has vorticity. Each congruence line ‘sees’ nearby world lines rotating around them, at fixed distance. This turns out to make it impossible to find a slice orthogonal to all of a bundle of the congruence world lines.
Likes Dale and Nugatory
  • #32
246393
The cyan lines are the worldlines of clocks moving on a circular track, with their ticks marked by the red blobs. The green line joins one set of blobs, which is a chain of clocks each Einstein synchronised to its neighbour (in fact, if you slit the cylinder along the white line and flattened it out, the green line would be the x-axis of a frame moving at ##v=\omega r##). But this approach inevitably goes wrong somewhere - as can be seen from the failure of the green line to close.
  • #33
There is no actual space-like surface that corresponds to the surface of the disk, but mathematically one can project the worldlines of the disk in the 4 dimensional space-time manifold to a 3-dimensional "quotient space". With the understanding that this is a quotient space, and not any sort of surface, we can then discuss the spatial geoemtry of the quotient space. The technique is most applicable to a disk that spins at a constant angular velocity.
A paper that discusses this approach is "Relative space: space measurements on a rotating platform" by M. L. Ruggerio, https://arxiv.org/abs/gr-qc/0309020.
I like Ruggerio's approach, because it ties the notion of distance in the quotient space to the then-current SI defintion of the meter as the distance light travels in 1/c seconds, c being the defined constant, the speed of light. It's got a reasonable number of citations according to google scholar, though I'm sure there are papers on the rotating disk with higher citation counts.
  • #34
I am well aware of that approach, and agree it is possibly the best notion available, but it does not give you an intuitive notion of the body as a whole. I think the rotating disk is important precisely because it is the simplest example in SR of the general fact that a the whole notion of a body undergoing arbitrary motion in SR breaks down. The general case in SR is the congruence of particle world lines bounded by a world tube with no well defined notion of a body as a whole undergoing motion and rotation.
In particular, finite distance calculated on quotient space don’t correspond to any measurement. Only ultralocal distances correspond to radar distances.
Likes PeterDonis
  • #35
I don't agree. Unless I've completely misunderstood this, it's exactly what you'd measure with a tape measure.
<h2>1. What is relativistic centrifugal force?</h2><p>Relativistic centrifugal force is the apparent outward force experienced by an object in a rotating frame of reference due to its inertia, as described by the theory of relativity.</p><h2>2. How is relativistic centrifugal force different from regular centrifugal force?</h2><p>Relativistic centrifugal force takes into account the effects of time dilation and length contraction on an object's motion, while regular centrifugal force does not. It is a more accurate and comprehensive explanation of the forces at play in a rotating frame of reference.</p><h2>3. What is the formula for calculating relativistic centrifugal force?</h2><p>The formula for relativistic centrifugal force is F = mω²r, where F is the force, m is the mass of the object, ω is the angular velocity, and r is the distance from the center of rotation.</p><h2>4. Does relativistic centrifugal force have any practical applications?</h2><p>Yes, relativistic centrifugal force is important in understanding the motion of objects in rotating systems, such as in centrifuges and particle accelerators. It is also relevant in the study of celestial bodies and their orbits.</p><h2>5. How does relativistic centrifugal force relate to the theory of relativity?</h2><p>Relativistic centrifugal force is a consequence of the theory of relativity, specifically the principle of equivalence, which states that the effects of gravity and acceleration are indistinguishable. It is a result of the curvature of spacetime caused by rotating frames of reference.</p>
  • Biology and Medical
