Answer: Find Relativistic Collision Momentum & Energy
He begins by setting up equations for energy and momentum conservation and using the fact that one of the masses is at rest to simplify the equations. However, he runs into difficulties and asks for guidance. Another student suggests using the relation between momentum and energy to find an expression for v_c, which James is able to successfully do.
bobred
173
A mass [tex]m[/tex] travels at 1.5 x 10^8 m s^-1 and collides with another mass [tex]m[/tex] at rest. The two masses fuse to become [tex]M[/tex] and travel away at [tex]v_c[/tex]. Find an expression for [tex]v_c[/tex] using conservation of relativistic momentum and energy.
[tex]E_a+E_b=E_c[/tex] and [tex]p_a+p_b=p_c[/tex]. With b at rest [tex]p_b=0[/tex] so [tex]p_c=p_a[/tex].
[tex]E_a=\frac{mc^2}{1-\sqrt{\frac{v^2}{c^2}}}[/tex] (1)
[tex]E_b=mc^2[/tex] (2)
[tex]p_a=\frac{mv}{1-\sqrt{\frac{v^2}{c^2}}}[/tex] (3)[tex]E^{2}_{tot}=M^2c^4+p^2_cc^2[/tex] (4)
Energy conservation
[tex]\frac{mc^2}{1-\sqrt{\frac{v^2}{c^2}}}+mc^2=\frac{Mc^2}{1-\sqrt{\frac{v^2_c}{c^2}}}[/tex]
Momentum conservation
[tex]\frac{mv}{1-\sqrt{\frac{v^2}{c^2}}}=\frac{Mv}{1-\sqrt{\frac{v^2_c}{c^2}}}[/tex]
Inserting the above into eqn 4
[tex]\frac{M^2c^4}{1-\frac{v^2_c}{c^2}}=M^2c^4+\frac{M^2v^2_cc^2}{1-\frac{v^2_c}{c^2}}[/tex]
Am I on the right path? I can't seem to get sensible answer for [tex]v_c[/tex]
Try using the relation v/c = pc/E.
Got it thanks
[tex]p_c=\frac{Mv_c}{1-\sqrt{\frac{v^2_c}{c^2}}}[/tex] (1)
[tex]E_c=\frac{Mc^2}{1-\sqrt{\frac{v^2_c}c^2}}}[/tex] (2)
Dividing (1) by (2)
[tex]\frac{p_c}{E_c}=\frac{v_c}{c^2}[/tex] so [tex]v_c=\frac{E_cc^2}{p_c}[/tex]
James
1. What is relativistic collision momentum?
Relativistic collision momentum refers to the total momentum of a system before and after a collision, taking into account the effects of special relativity. It takes into account the mass, velocity, and energy of the particles involved in the collision.
2. How is relativistic collision momentum calculated?
The relativistic collision momentum can be calculated using the equation p = mv/√(1-v^2/c^2), where p is momentum, m is mass, v is velocity, and c is the speed of light. This equation takes into account the effects of special relativity and is used for high-speed collisions.
3. What is the difference between relativistic and classical collision momentum?
Classical collision momentum only takes into account the mass and velocity of particles, while relativistic collision momentum also considers the effects of special relativity, such as time dilation and length contraction. This is important for collisions involving particles traveling at very high speeds, close to the speed of light.
4. How is energy related to relativistic collision momentum?
Energy and momentum are closely related in relativistic collisions. The relativistic energy equation, E = mc^2/√(1-v^2/c^2), can be used to calculate the total energy of a system, taking into account the effects of special relativity. This energy can then be used to calculate the relativistic collision momentum.
5. What are some real-world applications of relativistic collision momentum?
Relativistic collision momentum is important in fields such as particle physics, where particles are accelerated to high speeds and collide in order to study their properties. It is also relevant in astrophysics, where the collisions of objects in space can involve extremely high speeds and require the use of special relativity in calculations.
