Relativistic elementary particle problem
dreamspy
We have the decay process:
pion --> muon + anti muon neutrion
How long does the muon travel before it decays? (the pion is stationary before the decay)
The answer is supposed to be
d = c * t (m(pi)^2 + m(mu)^2) / (2 m(pi) * m(mu) )
where t is the mean lifetime of the muon in it's center of mass system.
Now I know about the conservation laws of energy and momentum.
Also from the form of the formula for d, I see that we should have d/t = v , where v is the speed of the muon. The speed is related to the momentum by p = mv. So I should try to find the momentum p of the muon. Now I say that the neutrino is massless and define the change in rest energy to be:
delta E = c^2 ( m(pi) - m(mu) )
This energy should then give the muon and the neutrino some momentum and kynetic energy. So I should use the conservation laws to find p and then the problem should be finished. But I haven't been able to show this. Anyone have any clue how to do this?
regards
Frímann
You should be using relativistic expressions for all quantities. p =mv is not true when the effects of special relativity are important.
This is not a useful quantity. You should compute the energy of the pion, muon and neutrino and directly apply energy conservation.
regards
Frímann
Indeed you want to apply conservation of energy and momentum to find the energy and momentum of the muon. By comparing this to the rest energy of the muon, you can determine the Lorentz transformation and then use this to compute the time dilation.
actually I was able to finish the problem using the foundation I posted in my first post. I simply say that the extra energy is divided to the kinetic energy of the muon and the neutrino:
delta E = T(muon) + T(Neutrino)
The momentum of the muon and the neutrino are equal but in oposite directions:
|p(muon)| = |p(neutrino)| = p
Then I simply use:
T(muon) = E(muon) + E0(muon)
where E(muon)^2 = (cp)^2 + (E0)^2
and E0 = m(muon) c^2
Now equating the two functions for delta E will then give you the correct answer at least according to the problem. Although p=mv is not always valid.
regards
Frímann
OK, I just thought there's less room for confusion in general if you just apply energy conservation directly as E(initial) = E(final)
Then I simply use:
You either mean
E(muon) = T(muon) + E0(muon)
or
T(muon) = E(muon) - E0(muon)
Right. If you can work entirely in terms of the momentum and energy you won't have a problem. If you need to compute a velocity you need to use the correct formula.
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
