What is Relativistic Heat Force? Any Research Papers on This Topic?
Frank Lampard
Can anyone explain me the term 'Relativistic heat force'?
Any research papers dealing with this topic??
Thanking in advance..
A Google search on "relativistic heat force", using quotes to keep the words together in that exact sequence, turns up exactly two hits, both of which refer to your posting. (Wow, is Google fast, or what? :bugeye:)
Perhaps it would help us if you can say where you saw this phrase, and what the context was. I don't claim to be an expert on current developments in relativity or thermodynamics, but I'm pretty sure I've never seen this phrase before.
I had found it in a paper called "Thermodynamics meets Special Relativity
– or what is real in Physics?" by Manfred Requardt.
Here's the link--arXiv:0801.2639v1 [gr-qc] 17 Jan 2008
The linked paper http://arxiv.org/PS_cache/arxiv/pdf/0801/0801.2639v1.pdf has something very odd in it. I hope someone can clear up what seems a very basic error in the paper.
In equation (2) the paper clearly states \gamma = (1-u^2/c^2)^{-1/2}
In equation (7) the paper states m = m_o \cdot \gamma = m_o \cdot (1-u^2/c^2)^{-1/2}
So far, this all very classic relativity but perhaps a bit old fashioned in using the relativistic mass increase concept. Nevetheless we note that by the expression m_o dot gamma they mean an increase of mass with increase of relative velocity.
Now just before equation (26) the paper states:
"Using the above expression for G, the fact that p is a Lorentz invariant, i.e. p = p0, and the change of volume by Lorentz contraction, V = V_o \cdot \gamma , one can integrate the above expression and get.."
Now of course I am very happy that they assume that pressure is invariant as everyone here knows that is my belief, but by V_o dot gamma they must be implying an increase of volume with increase of relative velocity. Is that not the opposite of length contraction and therefore a mistake? Maybe it is me that missing something basic?
It's a typo. The authors use V=V_0 \gamma ^{-1} a few lines below in eq (28).
Thanks! The typo really threw me :P
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
