Relativistic particle in a box
actionintegral
Hello,
I was wondering about the Shroedinger equation. I know about the "particle in a box" solution, but I was wondering what happens when the box is moving by at velocity v? And then as v approaches c? What does the equation look like?
actionintegral said:
Hello,
If it's moving relativistically, you would need a new prescription for studying things.
However, otherwise...
I would suggest that you try writing down the classical Lagrangian for such a system in a moving frame, and then come up with the Hamiltonian for such a system, and operatorize the Hamiltonian to get the new quantum Hamiltonian. It's an interesting exercise to see what happens to QM in a moving reference frame.
Ok I will try that.
You need to remember that the volume of the box changes with frame. So your particle density (which is |\psi|^2 in the SE but will need to be modified for a relativistic equation) should too...
Well, the Schrodinger Equation is not Lorentz invariant. While your question seems simple enough, I don't believe there is a consensus on how to correctly do it.
From the moment that your particle starts to have kinetic energies comparable to its rest energy, a single-particle quantum theory will not do anymore. You have to switch to, at your choice: a multi-particle theory, or a field theory. Happily, both are equivalent.
This morning I did the free particle schroedinger equation using d'alembert's solution (x+vt, x-vt). I guess a particle in a box would be a standing wave solution with nodes at the edge of the box. No problem.
But in a moment of reckless whimsy, I set v=c and the equation still seemed to work. What's up with that?
what would prevent one from solving the Dirac equation for a free electron subject to the constraint of the boundaries? (i have not actually tried this myself, maybe it could be done numerically with something like GAMESS?)
