Relativistic version of Newton's second law with parallel force
2 replies · 7K views · last reply
MasterNewbie
"Given F=dp/dt. If the force is parallel to velocity show that F=γ3ma."
F=dp/dt and p=γmv
Since the force is the first derivative of the momentum with respect to time, and γ and v both vary with time since there is a net force causing both quantities to change, take the derivative of p using multiplication rule: dp/dt = m[γ'v+γa] γ'=γ3*v/c2 so this would change dp/dt to dp/dt = m[γ3(v/c)2+γa] After this I can't think of anywhere to go that could simplify this to the desired equation F=γ3ma.
are you sure about [tex]\gamma[/tex] and its derivative? there must be something wrong about it
Yeah, I did the derivative wrong, I forgot to do chain rule for the v2 so the derivative of γ would be γ3*va/c2
So then dp/dt = γma[γ2(v/c)2+1]. Assuming the math I did was right the only way I could get what I'm looking for is if (v/c)2 is equal to 1-1/γ2 so when you distribute you'd get γ2-1+1, then it would give dp/dt = F = γ3ma what I'm looking for.
I'll have to mess around with this.
[edit]
Coincidentally (v/c)2 does equal what it needs to equal to simplify to what the equation needs to be.
Thank you a lot Pull :)
[/edit]
