Use relativity and the Larmor formula to calculate Lienard's formula
unified
Use relativity and the Larmor formula to calculate Lienard's formula.
Larmor Formula, Lienard Formula
I am trying to understand the solution to exercise 12.71 in the document linked below which accompanies Griffith's book on electrodynamics. The problem states that we are to use the Larmor formula and relativity to derive the Lienard formula. $$Larmor \ {} formula: P = \frac{\mu_0q^2a^2}{6\pi c} \ {} when \ {} v = 0$$ $$Lienard's \ {} formula: P = \frac{\mu_0q^2\gamma^6}{6\pi c}\left (a^2 - \left|\frac{\mathbf v \ {} \times \ {} \mathbf a}{c}\right|^2\right)$$ In the book it mentions that ##k^\mu = \frac {dp^\mu}{d\tau}## is a four-vector and ##k^0 = mc\frac {d^2t}{d\tau^2} = \frac {1}{c}\frac{dE}{d\tau}##. As you can see in the solution, from this Griffiths begins searching for any four-vector he can think of whose time component is equal to the Larmor formula when v = 0, concluding that the time component of such a four-vector should be ##\frac{1}{c}\frac{dE}{d\tau}##. The four-vector he gives is $$k^\mu = \frac{1}{4 \pi \epsilon_0}\frac{2}{3}{q^2}{c^5}\alpha^v\alpha_v\eta^\mu$$ The time component equals the Larmor formula (times 1/c) when v = 0, and he calculates P in terms the time component and finds that P is equal to Lienard's formula.
$$\\$$ It's hard for me to see what motivated Griffiths to start searching for any four-vector he could think of whose time component is the Larmor formula (times 1/c) for v = 0, and then reach the conclusion that the time component must be ##\frac{1}{c}\frac{dE}{d\tau}##. Moreover, ##\frac{d^2t}{d\tau^2}## = 0 if v = 0, so isn't the proper power and therefore the ordinary power zero when v = 0, in contradiction to the Larmor formula? The four-vector he's constructed is not ##\frac {dp^\mu}{d\tau}##, and the time component is not ##mc\frac{d^2t}{d\tau^2}##, although his notation suggests otherwise, writing ##k^0## at the beginning of his solution, and later ##k^\mu## for his four-vector. So, I can't understand how he came up with this idea and conclusion, and how these formulas are consistent with ##\frac{d^2t}{d\tau^2} = 0## when v = 0 which should imply that the proper power and therefore the ordinary power are zero when v = 0.
https://media.physicsisbeautiful.com/resources/2019/02/18/solutions_manual.pdf
To clarify, in the book by Griffiths, we have ##p^\mu \equiv m\frac{d}{d\tau}\eta^\mu## and ##E \equiv cp^0##, so by definition, ##\frac{dE}{d\tau} = c\frac{dp^0}{d\tau} = m\frac{\mathbf u \cdot \mathbf a}{(1 - u^2/c^2)^2}##. Evaluating the proper power in a coordinate system where the particle is instantaneously at rest, ##\mathbf u = 0## we have ##\frac{dE}{d\tau} = 0##, which seems to disagree with the Larmor formula. I do not question the Larmor formula, but I'm lost on how we're defining energy and the power of the accelerating charged particle. Obviously, it couldn't be the presentation given above. Yet, that was simply how the energy is defined in the book and shouldn't be wrong by definition.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
