Relativity at cern - deflection
RK1992
obviously an electron will change path when passing through a field
could anyone point me to an equation which suggests how much electrons change path by - i guess it depends on mass, velocity (maybe in the form of momentum for the relativistic case I am think of?), field strength and the charge of the particle
thanks in advance
i just thought
could you approximate the LHC as circular motion, then use f=mv^2/r to calculate the force needed to give the particle a centrepetal acceleration? the using some sort of particle in field equation, calculate the field strength needed to provide the centrepetal force as momentum increases?
i just don't know where i can find an equation telling you how much force fields will apply to a particle, ca anyone help there?
Use the Lorentz-force equation:
F = q(v X B)
F is the centripital acceleration to keep the particle in a circular orbit. For v in the LHC, use c = 3 x 108 m/s.
Here are approx numbers. LHC circumference is ~26 Km. It takes ~ 9 Tesla (average) to keep a 7 TeV proton in orbit.
Bob S
F = q(v X B)
Bob S
i'm not familiar with the cross product yet (im 17, starting further maths right now, and cross product is a few months away)... is v X B just constant times constant?
when you say "F is the centripital acceleration to keep the particle in a circular orbit.", do you mean i substitute in the expression f=mv^2/r ?
thanks in advance
The math is complicated, see https://www.physicsforums.com/blog.php?b=1887
eugh.. i think i should give up this project its way out of my league just yet :(
Here is a short-hand formula used by high energy accelerator physicists (βγ Mc2 = relativistic momentum in pc units):
Beam rigidity Bρ = βγ Mc2/c Tesla-meters, where ρ is bending radius.
Here ρ = 26,000m/2 pi = 4140 meters. B = [STRIKE]9[/STRIKE] 6.6 Tesla*, so Bρ = [STRIKE]37,300[/STRIKE] ~27,300 Tesla meters,
So βγ Mc2 = 3 x 108 x 27,300 T-m = ~8.1 TeV. Actual number is 7 TeV per beam.
* the bend magnet field at full energy is ~8.3 Tesla, and the magnets occupy ~ 80% of the ring, so the average field is ~6.6 Tesla.
Bob S
[added] From the LHC Design Report, the bend field is 8.33 Tesla, and the bend radius is 2804 meters, so cBρ = 7.00 TeV
See www.cern.ch/lhc Chapter 2 in Vol 1.
So beam rigidity is just the product of the bending radius and the field strength? Is this property just as it suggests - the rigidity of the beam being how hard the stream of particles is to curve into a circle?
how innaccurate is this short-hand in comparison with using the lorentz force law or whatever it is you need?
i can't see a volume 1 or chapter link on that page anywehrre :/
you guys here are great, youre so helpful.. pretty selfless to spend your time helping strangers you don't know prepare for physics degrees
Yes and yes.
The rigidity equation is exact for both relativistic and non-relativistic charged particles. See equation 2.6 in
See http://books.google.com/books?id=S8...ook_result&ct=result&resnum=3&ved=0CBwQ6AEwAg
Here p is the relativistic momentum, which for a particle of charge e and total energy E is sqrt[E2 - (m0c2)2]/c = βγ m0c
www.cern.ch/LHC
click on Design Report
click on Beam Parameters
Bob S
i just came up witha question: what on Earth are pc units?
RK1992 said:
i just came up with a question: what on Earth are pc units?
For relativistic particles with total energy E , E2 = (pc)2 +(mc2)2
where mc2 is the rest mass and pc is the momentum times the speed of light. So it is very easy to use the same units for momentum as for the rest mass and the total energy. The actual momentum p might be in GeV/c ("GeV per c") units, but using GeV for pc is easier.
As stated in a previous post, the particle rigidity is Bρ = (pc)/c = p Tesla-meters, which is in momentum (i.e., GeV/c) units.
Bob S
