Enhance Range for Remote Audio and Video with ASK Transmitter Modules
  • Thread starter Thread starter Tesladude
    Audio Video
A user inquires about enhancing the range of a small remote camera with audio, which currently has a limited range of 30 feet. They propose using ASK transmitter modules to extend the range by rerouting the data line from the camera through a higher-range module. However, it's noted that without specific details about the existing transmitter and receiver, it's unlikely to work due to potential bandwidth limitations for video signals. A suggestion is made to explore a specific product link for potential solutions. Overall, the feasibility of this enhancement is questioned due to technical constraints.
Tesladude
Hi I think this may be a dumb question but what the heck...
So i have a very small remote camera with audio, the thing is the size of like 4 dice.
But it doesn't have good range with the reciever, only like 30'.
I do a lot of electronics and have made remote controll circuits useing encoaders and decoaders paired with ASK transmitter modules, so if I was to take the the data line going to the transmitter circuit board of the camera and run it through an ASK module that has greater range, then do the same on the reciever, would it work?
Although this question is impossible to answer without knowing the details of the transmitter and receiver, it it doubtful that it would work because it is unlikely either the transmitter or receiver will have enough bandwidth to handle a video signal.
Why don't you try this? http://www.hobbytron.com/pdf/Tv6E.pdf
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
