Replace solar panels by thermopiles
Replacing solar panels with thermopiles for street lighting is proposed, utilizing sewers as heat sinks due to their lower cost and lack of doping requirements. However, the effectiveness of this idea depends on the quality and temperature stability of the sewer systems, which can vary significantly. Concerns are raised about the efficiency of thermopiles, as they typically have low output and high costs, making them less viable without significant advancements. Additionally, the heat differential at night may not be sufficient to power street lights effectively. Overall, while the concept is intriguing, practical challenges and limitations need to be addressed for successful implementation.
chhitiz
i was thinking- how about replacing solar panels by thermopiles for street lighting and using the sewers as a heat sink. they don't have to be doped and so are cheaper. any reason why this idea hasn't been used before?
Science news on Phys.org
You'd have to have a great sewer. I mean there's this building in downtown Pittsburgh that in the winter you can walk by it and always there is hot steam coming out of the manhole covers on the southwest corner. But other than that I know of no other in Pittsburgh. I'd be willing to bet that in the summer time there is no discharge of heat there though. Oh yes I just read you said for a sink... Herm. In the summertime there's probably a 10 degree difference due to the heat island effect. Again I'll bet it would be picky for the individual sewer. I for one am not keen to go nosing around to find out :) But, I guess if you have the opportunity, go for it :) I'm wondering though, why not just plaster the sink onto the water mains? It seems like you'd get a lot more flow at a more stable, cooler temperature. Wouldn't you have to have a pretty huge thermopile to get the kinda wattage (300 I'd guess?) to drive a street light? I mean at night time the heat differential isn't going to be all that superb. The more humid the environment, the more the atmosphere retains the heat from the daytime, so places like east coast, mid west, and south east are in, arizona and southern california are out. If you ever do make some measurements of the heat differential, and then calculate the size of the thermopile you'd need along with the wattage you're going to need for the light, I'd love to hear the results :)
Dan K
The typical efficiency of a thermopile is quite low even in the most desirable temp range. The cost vs output is also quite high. To be viable, both would have to see very large improvements from present art.
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
