Required mass for hydrogen burning in stars
To calculate the required mass for hydrogen burning in stars at a temperature of 4*10^6K with a mean molecular weight of 0.62, the relevant equations include (R/Rsun)=(M/Msun)^(3/7) and T=(μG)/(2Rr). The energy per nucleon in the proton-proton (PP) chain process is approximately 6.5 MeV, which needs to be factored into the calculations. There is uncertainty about the correct application of the equations, particularly in relation to the energy per nucleon. Additional resources, such as lecture notes from an astronomy course, may provide further clarification on this topic.
ted1986
Hello all!
I have to calculate the required mass to ignite the PP chain when the given temperature is 4*10^6K and \mu=0.62. (I know the answer is about 8% from the sun's mass)…
I don't know exactly how to do it :-/ I know that (R/Rsun)=(M/Msun)^(3/7), The energy per nucleon in PP process is about 6.5MeV… I guess I need to use the formula: T= (\muG) /(2Rr) when R is the gas constant and r is the radius (This formula was evaluated from the ideal gas law)… I don't know how to consider the energy per nucleon in this equation…
Could someone help me please…
Thanks! :)
Astronomy news on Phys.org
Is there an equation that will give you the temperature of the gas/plasma based on the mass of the object? Would that help at all?
There is the equation F=-((4*a*c)/(3rho*kappa))*T^3*(dT/dr), but I don't think it's the right equation to use...
I wish I could help you further. Perhaps someone else will.
ted1986 said:
Hello all!
Thanks! :)
These lecture notes from an astronomy course might be beneficial...
http://www.ucolick.org/~krumholz/courses/fall09_ast112/notes14.pdf"
...answers the exact question. Of course you could just derive them yourself :-)
TL;DR Summary: In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect alien signals, it will further expand the radius of the so-called silence (or rather, radio silence) of the Universe. Is there any sense in this or is blissful ignorance better? In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect...
Thread 'Could gamma-ray bursts have an intragalactic origin?'
This is indirectly evidenced by a map of the distribution of gamma-ray bursts in the night sky, made in the form of an elongated globe. And also the weakening of gamma radiation by the disk and the center of the Milky Way, which leads to anisotropy in the possibilities of observing gamma-ray bursts. My line of reasoning is as follows: 1. Gamma radiation should be absorbed to some extent by dust and other components of the interstellar medium. As a result, with an extragalactic origin, fewer...
Both have short pulses of emission and a wide spectral bandwidth, covering a wide variety of frequencies: "Fast Radio Bursts (FRBs) are detected over a wide range of radio frequencies, including frequencies around 1400 MHz, but have also been detected at lower frequencies, particularly in the 400–800 MHz range. Russian astronomers recently detected a powerful burst at 111 MHz, expanding our understanding of the FRB range. Frequency Ranges: 1400 MHz: Many of the known FRBs have been detected...
