Resistance and current problems
The discussion addresses three problems related to electric current and resistance. For Problem 5, the current resulting from a doubled charge of 24mC over 3.1 seconds is calculated using I = Q/t, yielding 7.74 A. In Problem 7, the time required for 7.5 C of charge to pass through a copper wire with a current of 19 A is found to be 0.39 seconds using the same formula. Problem 11 involves calculating the resistance of a television drawing 2.8 A at 121 V, resulting in a resistance of 43.2 ohms using Ohm's law. These calculations illustrate fundamental principles of electric current and resistance.
mustang
Problem 5.
A total charge of 12mC passes through a cross-sectional area of a nichrome wrie is 3.1s.
If the number of charges that pass through the cross-sectional area furing the given time interval doubles, what is the resulting current? In units of A.
Note: What formula(s) should I use?
Problem 7.
How long does it take for 7.5 C of charge to pass through a cross-sectional area of a copper wire if I=19A? In units of s.
Note: I don't know where to start?
Problem 11.
A typical color television draws 2.8 A of current when connected across a potential difference of 121V.
What is the effective resistance of the television set? Answer in omega.
Current can be defined as the charge which passes a given point in one second. Specifically, 1 ampere of current is 1 coulomb of charge passing a given point in one second.
If you have 12 milli-coulombs pass in 3.1 seconds then it's a simple matter to calculate how many coulombs are passing in 1 second. That would be the current in amperes. Current (in amperes) equals Charge (in Coulombs) divided by time (in seconds). I=C/T
If charge doubles, then it's easy to see what happens to current by looking at the formula. Current is directly proportional to charge.
Here we are given 19 amperes of current and are asked to find the time it takes 7.5 coulombs of charge to pass a given point. First ask yourself how many coulombs are passing a given point in one second. If we have 19 amperes of current, we have 19 coulombs of charge passing any given point in one second. If it takes 1 second for 19 coulombs of charge to pass, how long will it take for 7.5C of charge to pass?
Simple ohms law problem:
Voltage(V)= Current(I) * Resistance(R)
To find resistance, R=E/I.
For Problem 5, we can use the formula for current, I = Q/t, where Q is the charge and t is the time. Since the number of charges doubles, the new charge would be 24mC. Plugging this into the formula, we get I = 24mC/3.1s = 7.74 A.
For Problem 7, we can use the same formula, I = Q/t, where Q is 7.5 C and I is 19 A. Rearranging the formula to solve for t, we get t = Q/I = 7.5 C/19 A = 0.39 s.
For Problem 11, we can use Ohm's law, R = V/I, where R is the resistance, V is the potential difference, and I is the current. Plugging in the values, we get R = 121V/2.8A = 43.2 ohms.
