Resistance in circuits with transformers
Transformers operate on electromagnetic induction, where the voltage and current in the secondary coil depend on the primary coil's specifications and the turns ratio. In the given scenario, a primary coil with 10V and 1A results in a secondary coil output of 2V and 5A, illustrating the step-down transformation. The calculated resistances show that the secondary coil has a lower effective resistance of 0.4Ω compared to the primary's 10Ω. This lower resistance in the secondary coil implies that a resistor placed there would experience a more significant percentage power drop than the same resistor in the primary coil. Understanding resistance in transformer circuits is crucial for analyzing power distribution and efficiency.
Pharrahnox
I am starting to learn about transformers, and know the basics: they use electromagnetic induction to induce a current in a secondary coil, and the voltage and amperage of that second coil are dependant on the voltage and amperage of the first coil, and the ratio of turns in each coil.
So, here is a little scenario, then I'll get onto the question.
Say I have the primary coil running at 10V and 1A, with 100 turns in the coil. In the secondary coil, I have 20 turns in the coil.
The secondary coil would then have 2V and 5A (assuming an ideal transformer).
Now for the question. When using Ohm's Law (V = IR --> R = V/I), it would seem that the primary coil has 10V/1A = 10Ω of resistance, and the secondary coil has 2V/5A = 0.4Ω of resistance.
Does this then mean that the effective resistance of the secondary coil is lowered in a step-down transformer? Does this also mean that a 10Ω resistor in the seondary coil would cause a larger power drop (P = VI) percentage-wise than it would in the primary coil? (10+10 = 20/10 = 200%, 0.4+10 = 10.4/0.4 = 2600%)
I would like to learn more about reistance in transformer circuits, so any links would also be appreciated. Thanks for any replies.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
