johndoe
- 41
- 0
A resistor in parallel with a voltage source or a resistor in series with a current source has no effect on the rest of the circuit?
johndoe said:A resistor in parallel with a voltage source or a resistor in series with a current source has no effect on the rest of the circuit?
rbj said:if these are ideal voltage or current sources and you are analyzing a circuit and trying to reduce it to a less complex representation, then the answer is yes, that is the case and they definitely have no effect on the rest of the circuit. i cannot account for what these other guys are saying. they're either assuming a non-ideal voltage or current source (for which you need to model in the series resistance for a voltage source or a parallel resistance for the non-ideal current source), or they're mistaken.
and it has nothing to do with whether they are current-controlled or voltage-controlled or independent sources.
Type_R said:He asked if a resistor in parallel with a voltage source have effect on the circuit...
Even with an ideal voltage source... the current is changed as it flows through the resistor...That's an effect.
I understand where you're coming from though.
Also his question was very vague...You can put a resistor in parallel with a voltage source...but he never stated what the "rest of the circuit" consisted of.
rbj said:not on the rest of the circuit. the ideal voltage source says (a super-duper highly regulated power supply that has the whole power utility backing it up) that it will deliver the rated voltage no matter what current it has to dump out. theoretically, with an ideal voltage source, if you short circuit it, it will deliver infinite current. a resistor in shunt with the ideal voltage source will simply cause it to dump out more current. the voltage remains the same and the rest of the circuit doesn't know the difference. that resistor shunt can be removed and the rest of the circuit doesn't know the difference.
you can say the same thing about the ideal current source but exchange the words "voltage" and "current" and replace the word "shunt" (or "parallel") with "series".
i don't think that you completely understand this. this is basic linear electric circuits in the electrical engineering discipline. we use these techniques (along with the Thevenin/Norton equivalents and parallel/series formulae for components) to simplify circuit analysis.
it doesn't matter what the rest of the circuit is as long as it isn't something pathological like two ideal voltage sources (with different voltages) in parallel or two ideal current sources (with differing currents) in series. those pathological cases end up in contradiction and cannot be solved.
Type_R said:I'm not sure how to use these threads that well...But here's a picture to help illustrate my point
http://img519.imageshack.us/img519/9540/circuityu9.jpg
The more resistors you add the more current you'll measure with the current meter inserted into the circuit.
dlgoff said:Depends on the internal resistance of the voltage source and the resistor value.
Type_R said:Well this is turning to be a semantics issue for me...Because the way I see "rest of the circuit" is... "electron flowing from the negative potential all through the circuit until it reaches the positive potential" so I see that part of the circuit were I placed the amp meter as after the resistor making it "The rest of the circuit."
quadraphonics said:Right, the ammeter in post #10 needs to be between the two resistors, and not between the resistors and the source, to measure what's going on in the rest of the circuit. As is it's measuring what's going on at the source.
