Resize distortion of Motion blurred Image
  • Thread starter Thread starter Chriszz
    Image Motion
Resizing motion blurred images can introduce various distortions that affect both human perception of sharpness and image signal processing. Distortions may include changes in clarity and detail, impacting how viewers interpret the image's quality. For image signal processing, resizing can complicate the restoration of sharpness and introduce artifacts. Resources for further reading include academic journals and online searches for mathematical corrections and stabilization techniques. Understanding these factors is crucial for effective image manipulation and enhancement.
Chriszz
Dears,
Thesedays, I'm studying the image distortion, especially, about the motion blurred images.
About these works, I have some questions and I can't find answers myself.
My questions are following:
1. When resizing motion blurred images, what types of distortions could be applied additionally?
How this process affect on motion blurred images? In terms of 1) human perception of sharpness and 2) image signal processing.
2. Could I find some journal papers about the above question?
Thank you in advance.
Regards,
There are certainly transforms regarding motion of images and applying correction equations. You can preform a google search for these and learn for your self what math is available to correct or stabilize images. And as far as journal papers go, search for those as well.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
