Resolution of forces(tension force)
  • Thread starter Thread starter bkvitha
    Force Resolution
4 replies · 6K views
bkvitha
View attachment Forces.doc
The two diagrams show a load hanging with View attachment Forces.doc2 strings of the same size and type hanging from a flat plane.
Find the tention on each string for both situations.
I know that
Fy of both strings in Diagram 1 are equal.
Fy=Fy
Thus the
Fy=10 N
However, for the situation in the Diagram 2, I am not sure whether
Fy1 =Fy2
So, are both of the vertical components of both the strings at different angles equal?
~sorry I couldn't add a bmp file.~
bkvitha said:
The two diagrams show a load hanging with View attachment 81212 strings of the same size and type hanging from a flat plane.
You can answer this question yourself if you do a free body diagram showing all the Force vectors acting and do the analysis. But you can also just think about it a bit. Suppose you have a mass held by one string, vertically. Then you attach a second string from a long horizontal distance away to the mass and pull the mass a little horizontally. Are both strings providing the same vertical force?
Do the analysis:
You have the vertical components of the tension in each string acting up and mg acting down. What can you say about the sum of those forces?
You also have the horizontal components of the tensions acting in opposite horizontal directions. What can you say about the sum of those forces?
Now you have two equations with two unknowns (T1 and T2). You can solve for T1 and T2. You can work out the vertical components and see how they compare.
AM
I still don't get it.
But correct me if I'm wrong,
the vertical component is not distributed equally to bothe strings in the 2nd diagram.
Thus, each string at different angles from the wall possesses different magnitude for its vertical component(Fy).
That is correct, but it does not tell you how to divide the force between the two vertical tension components. You have to look elsewhere for the information to figure that out. The elsewhere is included in AM's post. What other tension components have you not yet considered?
Thanks for the tips and info AM n OD!
i shall work it out n present my results n workings , yeah!
You both have been great help since i got into PF!
TY for that.
