What is the difference between resonance in a vacuum and resonance in a medium?
Resonance occurs when an external force matches an object's natural frequency, causing increased amplitude of vibration. In a vacuum, there is no air friction, allowing for uninterrupted oscillations, while in a medium like water, damping effects reduce amplitude and sharpness of resonance peaks. The presence of a medium alters the resonant frequency due to factors like buoyancy. Therefore, resonance in a vacuum typically results in greater amplitude compared to resonance in a medium. Understanding these differences is crucial for applications in physics and engineering.
tennispro1213
So we're studying resonance.
It says that it occurs when an external periodic force acting on a body is exactly equal to the natural frequency of the body. The body then begins to vibrate with greater/increasing amplitude and intensity.
And so what I want to know is that is there a difference between the type of resonance that occurs in a vacuum and the type in a medium (say water) ?
Like in a vacuum, would a pendulum experiencing resonance continue to complete oscillations, or would it spin all the way around or something?
A vacuum simply implies no air friction, resonance occurs with or without a vacuum.
Resonance occurs because the driving force is in sync with the natural vibration of the object.
In simpler terms, the driving force always pushes in the direction of vibration, never against it, thus it allows the maximum increase in amplitude.
The driving force could be from anything, a person, a machine..
hi tennispro1213! welcome to pf! :smile:
tennispro1213 said:
… is there a difference between the type of resonance that occurs in a vacuum and the type in a medium (say water) ?
a pendulum is governed by mx'' = -mgsinθ
or approximately x'' = - (g/L)x
if you put the pendulum in a fluid, the buoyancy will change the RHS, and therefore change the resonant frequency
Ok, thanks for the answers guys.
I was just confused whether there is a difference in the increased amplitude produced due to resonance in different media.
I actually didn't clarify enough, sorry (First time using a forum (obviously)).
So what I'm asking is, would there be a greater increase in the amplitude of a body if resonance occurred in a vacuum, or would it be the same amount of increase in amplitude if resonance occurred in any medium?
(My reference to the pendulum was just an example, though thanks, that probably would have been my next question.)
The damping produced by the medium will indeed reduce the resonant amplitude. And will make the resonance peak less sharp.
See the graph here, for example:
http://en.wikipedia.org/wiki/Resonance
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
