Resultant Force on Charge in the middle of square
The discussion revolves around calculating the resultant force on a negative charge placed at the center of a square, with various charges located at the corners. The problem involves understanding the interactions between these charges and applying Coulomb's law.
  • Participants discuss the calculation of forces exerted by corner charges on the central charge, including considerations of symmetry and cancellation of forces. Questions arise regarding the treatment of equal and opposite forces and the determination of force components without specific numerical values.
Participants are actively engaging with the problem, exploring different approaches to calculate force components and questioning the assumptions made about charge interactions. Some guidance has been offered regarding vector addition and the conceptual breakdown of forces.
There is a mention of confusion regarding the absence of numerical values for charge and distance, which may affect the clarity of calculations. Additionally, the discussion includes a consideration of how to interpret the forces from the -4q charge by splitting it into two components.
katia11
(a) Find the resultant force on a negative charge of -3q, placed at the center of a square of side b, which has charges on the 4 corners, respectively, q, 2q, -4q, 2q in clockwise order. (Magnitude and direction)
F= k*q1*q*(1/ r^2)
Ftotal= F15 + F25 + F35 + F45
I drew the figure, and see that r = square root 2 *b* (1/2)
(pythagorean theorem)
One question is that F25 and F45 are equal and opposite. Do they cancel each other out? If so, I wouldn't have to calculate the forces for those, yes?
I'm just a little confused. Sorry if it's super easy.
F= k*q1*q*(1/ r^2)
I assume you mean:
[tex]r = \sqrt{2}b/2 = .707b[/tex]
Correct. Just draw each force vector and add them together (tail to head). You will see that the net force is in the direction of q.
AM
Ok awesome!
So now I have
F15= (2ke3q2)/(b2) N
and
F35=(2ke4q2)/(b2) N
But how do I find the x and y components without numbers? Do I just put in
F15x= F15 sin(135)
F15y= F15 cos(135)
and
F35x= F35 sin(135)
F35y= F35 cos(135)
The fact that there's no value for q shouldn't be throwing me off this much, but it is.
katia11 said:
Ok awesome!
So now I have
and
F35=(2ke4q2)/(b2) N
F15x= F15 sin(135)
F15y= F15 cos(135)
and
F35x= F35 sin(135)
F35y= F35 cos(135)
Think of the -4q charge as made up of two charges, +q and -5q. Draw the force vector resulting from each charge. The force vector from the +q charge cancels that from the opposite corner. You are then left with a single force vector from the -5q charge that is a distance .707b away. Apply Coulomb's law to determine the magnitude of the force. The direction is obvious. What is the angle between the force vector and one of the sides?
AM
45 degrees?
I think I was confused because I made the middle charge the origin and thought the angle came from that. . .
And I don't really understand why we split the -4q because if one if +q and one is -5q we would get a net result of -4q anyway. . .
I assume the direction is towards the first corner q.
Thanks so much again, sorry if something is going over my head. . .
  • · Replies 23 ·
  • · Replies 25 ·
  • · Replies 24 ·
