Resultant Frequency of two unlike soundwaves
When two sound waves of different frequencies, such as 340 Hz and 320 Hz, are combined, the resultant frequency is not simply the average but involves the principle of linear superposition. The amplitudes of the waves combine, while the frequencies remain distinct, creating a phenomenon known as beats. The resultant sound will exhibit a modulation in amplitude at a frequency equal to the difference between the two frequencies, which is 20 Hz in this case. To analyze the resultant wave mathematically, one can use trigonometric identities and functions to describe the waves. Understanding these principles is crucial for accurately determining the resultant frequency in sound wave interactions.
mckenna12
In a lab that my class was doing, we had to hit two tuning forks (of different frequencies) at the same time. One tuning fork had a frequency of 340 and the other had a frequency of 320Hz. I am aware that due to the Principle of Linear Superposition, when two sound waves are combined, the resultant is the sum of the disturbances from the individual waves.
My question is: what is the resultant frequency that is created? The amplitudes of the two waves are added together, but what about the two frequencies? Should it be around 330 Hz... the average of 340 and 320Hz?
Thank you.
You wrote,
"I am aware that due to the Principle of Linear Superposition, when two sound waves are combined, the resultant is the sum of the disturbances from the individual waves."
You need to first write down the functions that describe the two sources and then use the above.
See,
http://www.wolframalpha.com/input/?i=sin(320*2*pi*t)+++sin(340*2*pi*t)&cdf=1
You may need a plugin to view the above, its free and well worth the cost %^)You may also want to find the trig identity for,
Sina + sinb
See "Sum-to-Product formulas" in,
http://www.sosmath.com/trig/Trig5/trig5/trig5.html
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
