Reversibility in thermodynamics
The discussion centers on the concept of reversibility in thermodynamics, specifically how infinitesimal temperature changes can facilitate reversible processes. It is established that using a series of heat reservoirs at temperatures T1+dT, T1+2dT, etc., allows a system to return to its original state without significant work, as long as the temperature differences are negligible. The entropy change for the complete cycle approaches zero, confirming the theoretical basis for reversibility in thermodynamic processes. The importance of minimizing temperature differences to achieve reversibility is emphasized throughout the conversation.
  • Understanding of thermodynamic principles, particularly the concept of reversibility.
  • Familiarity with heat reservoirs and their role in thermodynamic processes.
  • Knowledge of entropy and its implications in thermodynamic cycles.
  • Basic grasp of temperature differentials and their effects on heat transfer.
  • Study the concept of thermodynamic cycles, focusing on Carnot cycles and their efficiency.
  • Explore the mathematical formulation of entropy changes in thermodynamic systems.
  • Learn about the implications of heat capacity in reversible and irreversible processes.
  • Investigate practical applications of reversible processes in engineering and physics.
This discussion is beneficial for students and professionals in thermodynamics, mechanical engineers, physicists, and anyone interested in the principles of heat transfer and energy efficiency in systems.
PhysicsInNJ
Conceptually, why does infinitesimally changing a system allow for a process to be reversible. For example, if we heat a system at temperature T1 to T2 by using a heat reservoir at T2, it is considered irreversible, but if we heat the system with many reservoirs at temperatures T1+dT, T1+2dT... the process becomes reversible.
I see that with the finite temperature difference, you would not be able to reverse the direction of heat flow without outside work, shouldn't the same problem exist for the "reversible" process, albeit with smaller magnitudes? You would not be able to spontaneously return a system at T1+dT to T1.
Science news on Phys.org
This is a very good question. First let me say that the word "spontaneous" implies irreversible in thermodynamics. So I don't think you meant to use that word.
The question is: How can both the system and the sequence of reservoirs be returned to their original state without doing any work and without having more than a negligible effect on anything else? Here is a hint to how one could proceed: On the reverse path, slightly shift the sequence of reservoirs that the system is brought into contact with. Can you figure out from this hint how to do it?
Chet
@Chestermiller If we put the system while it is in a T1 + 2dT configuration back in contact with T1+dT we could revert the temperature to T1 +dT. But this requires work on our part (outside work) to move the system and reservoir in contact, right? Also this wouldn't be able to bring the system back to T1.
I don't see why it would require work.
You put the system at temperature T+10dT into contact with the reservoir at T+9dT. Then you put the system at temperature T+9dT into contact with the reservoir at T+8dT. Then you put the system at temperature T+8dT into contact with the reservoir at T+7dT. etc.
I was thinking that if we were hypothetically carrying out this process, we would have to move the reservoirs/systems requiring us to do physical work.
But T+dT is the last reservoir we have, so the system would only be able to get down to T+dT, not return to T.
We could reduce such work to zero by putting the system in a frictionless sheet of ice as we moved it into contact with the various reservoirs. This really wouldn't be what we consider thermodynamic work.
Good call. Yes, we would have to add a reservoir at the one end, and not use the last reservoir at the other end. But, in the limit where dT really does approach zero, this would be a negligible effect.
Irrespective of the ##\Delta T## in each contact with a reservoir, the change in the entropy of the system would be zero for the complete cycle. The change in entropy of the reservoirs by doing this game plan for an arbitrary ##\Delta T## would be $$\Delta S=mC\Delta T\left(\frac{T_H-T_C}{T_HT_C}\right)$$ where ##T_H## is the high end temperature of the system, ##T_C## is the low end temperature of the system, and C is the heat capacity of the system. So, as ##\Delta T## gets smaller, the overall change in entropy for the combination of system and surroundings (reservoirs) would approach zero for the cycle.
I see, I suppose I was being pedantic and not considering the overall picture.
This made sense, thank you Chet!
  • · Replies 60 ·
10K
  • · Replies 29 ·
