Reversible adiabatic expansion/compression equal to zero
In summary, the change in entropy for a reversible adiabatic expansion/compression is equal to zero because no entropy enters or leaves the system and no entropy is created. In comparison, in an irreversible adiabatic process, entropy is created due to gradients, making the system's entropy constant. This is why the reversible process is an idealization. However, in a constant pressure heating of a non-adiabatic system, there is an increase in the system's entropy, a decrease in the surroundings' entropy, and creation of entropy at the interface due to the temperature gradient.
a9211l
So, I am looking a question about adiabatic expansions and the associated entropy changed.
Why exactly is the change in entropy for a reversible adiabatic expansion/compression equal to zero? The book says its because there is no heat transfer, but for irreversible adiabatic processes, there is also no heat transfer. So no matter what, shouldn't the entropy of the surroundings for an adiabatic process be zero? In terms of the system, since entropy is a state function, why would it matter whether its reversible or irreversible?
Hi a9211l, these are great questions. First, the adiabatic requirement just ensures that no entropy enters or leaves the system by way of heating. However, in an irreversible process we create entropy. Or it might be better to say it in reverse: when we create entropy through a mechanism like turbulence, the process is irreversible. The system will never spontaneously go back to its orginal state, because entropy always tends to increase in a closed system.
Thus, one answer to your question is that no entropy enters or leaves the system (work is a transfer of energy without an accompanying transfer of entropy), and no entropy is created. Therefore, the system entropy is constant.
So what would create entropy? Entropy is created whenever a process occurs due to a gradient (in charge, temperature, material concentration, etc.). This is how all real process occur: irreversibly. But we might imagine making the gradient very small to reduce the creation of entropy. This idea taken to its limit gives us the reversible process, an idealization in which we imagine the gradient to be exactly zero.
Is this helpful?
yes, that is very helpful. it made sense to me theoretically (idk if that's the right term...), but just needed that physical explanation.
A second question then, if I do a constant pressure heating of some non-adiabatic system, that still changes the entropy in the surroundings, correct?
Yes, heating a system increases the entropy of the system, reduces the entropy of the surroundings, and creates entropy at the interface due to the temperature gradient.
1. What is reversible adiabatic expansion/compression equal to zero?
Reversible adiabatic expansion/compression equal to zero is a thermodynamic process in which a system undergoes a change in volume without exchanging heat with its surroundings and without any change in its internal energy.
2. What is the significance of reversible adiabatic expansion/compression equal to zero?
This process is significant because it represents an idealized scenario in thermodynamics, where the system is perfectly insulated and there is no energy loss. It allows for the calculation of the maximum work that can be extracted from a system.
3. How is reversible adiabatic expansion/compression equal to zero different from other thermodynamic processes?
Reversible adiabatic expansion/compression equal to zero differs from other processes such as isothermal and isobaric processes in that there is no heat transfer involved. It also differs from irreversible processes in that it is a theoretical concept that cannot be achieved in reality.
4. Can reversible adiabatic expansion/compression equal to zero occur in real systems?
No, reversible adiabatic expansion/compression equal to zero is an idealized scenario that cannot be achieved in real systems. Some level of energy loss or heat transfer will always occur in practical situations.
5. How is reversible adiabatic expansion/compression equal to zero used in practical applications?
Although it cannot be achieved in reality, this concept is used as a benchmark for measuring the efficiency of real processes. It also plays a crucial role in the development of thermodynamic laws and principles, which are used to understand and analyze various systems and processes in engineering and science.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
