Reversible vs irreversible work for adiabatic process
The discussion centers on the net work done on a gas transitioning adiabatically between states A (P1, V1) and B (P2, V2) with P1>P2 and V2>V1. The net work is calculated by first expanding the gas reversibly from A to B using the equation w = dE = Cv(T2-T1), followed by an irreversible compression from B to A at constant external pressure P1, leading to a larger final volume and higher temperature due to viscous dissipation. The key conclusion is that to return to the initial state adiabatically, the process must be reversible, as irreversible processes do not allow for complete recovery of the initial state.
  • Understanding of adiabatic processes in thermodynamics
  • Familiarity with the concepts of reversible and irreversible work
  • Knowledge of the specific heat capacity at constant volume (Cv)
  • Basic principles of gas laws and state equations
  • Study the principles of adiabatic processes in thermodynamics
  • Learn about the differences between reversible and irreversible processes
  • Explore the concept of viscous dissipation in gas compression
  • Read the Physics Forums Insights article on reversible vs irreversible gas compression and expansion work
Students and professionals in thermodynamics, mechanical engineers, and anyone interested in the principles of gas behavior during adiabatic processes.
Andrew U
I have a gas transitioning adiabatically between A (P1, V1) and B (P2, V2) where P1>P2 and V2>V1. The question is to determine the net work done on the gas if the gas is first expanded reversibly from A to B (w = dE = Cv(T2-T1)), and then compressed irreversibly from B to A (w = -Pext(V1-V2)) at a constant external pressure defined by A. In this scenario, simply looking at the areas under the graphs the net work should be positive.I am trying to reconcile this with dE for the gas. For the roundtrip transition (A to B to A), dE = 0. And if we take each step as adiabatic, then dE = w for each step, but as I have described above you would end up with two different values for dE for each step, thus dE not equal to zero. My logic is flawed somewhere, can someone help?
Is this a problem you invented yourself, or is it out of a book?
Chet
The flaw in the logic is this: If you try to recompress irreversibly at constant P1, you will re-equilibrate at a volume greater than V1 before ever reaching V1. So, you won't be able to reach the initial state in this adiabatic irreversible recompression. You can calculate what final volume and final temperature the system reaches by irreversibly recompressing at P1. The only way you can back to the initial state adiabatically is if you do it reversibly.
Hi Chet, thanks! I invented this one (and obviously missed an important point). So if I end up at a larger volume, then my temperature must also be higher, correct? Is this because of friction during the irreversible compression?
Clarification: When I ask about the increase in temperature, I am referring to an additional increase that is larger than one would normally expect for an adiabatic compression, thus leading to a larger final volume.
Yes.
Yes. Viscous dissipation.
Don't despair. You invented a very interesting problem. I've seen other versions of this before.
For more details in irreversible vs reversible processes, see my Physics Forums Insights article: https://www.physicsforums.com/insights/reversible-vs-irreversible-gas-compressionexpansion-work/
  • · Replies 60 ·
10K
  • · Replies 22 ·
  • · Replies 27 ·
9K
