Revolution of Planets: Rotation & Revolving Around Stars
Planets continuously rotate on their axis and revolve around stars due to the conservation of angular momentum and gravitational forces. They do not consume energy for this motion; instead, their spin energy remains constant while their orbital kinetic energy fluctuates with changes in gravitational potential energy. Since there is no friction in space, planets do not lose energy or slow down over time. Consequently, they do not expel heat as a result of their motion. The mechanics of planetary motion are governed by fundamental physical laws that ensure their continued rotation and revolution without energy consumption.
saket agrawal
How do planets continuously rotate on their axis or revolve around stars ? Do the energy they consume for this continued motion gets expelled as heat ?
Explain to yourself how they can not.
No energy is consumed for this. A planet in orbit has constant energy: its spin energy is constant, and its orbital kinetic energy changes by the opposite amount that its gravitational potential energy changes.
Also, if they were consuming energy (which they are not) then they would have to absorb heat (which they do not). Expelling heat would be exactly backwards.
There's no friction, so nothing slows down planets. Gravity do not "consume" any energy
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
