Reynolds Number in Organism-Fluid Interactions
The discussion revolves around the concept of Reynolds number in the context of organism-fluid interactions, particularly focusing on fish larvae and their swimming dynamics in different fluid environments. Participants explore the implications of Reynolds number on the behavior and survival of fish larvae, as well as the differences between low and high Reynolds number scenarios.
  • Some participants express confusion about the definition of Reynolds number as the "ratio of inertial forces to viscous forces" and how it applies to organisms in fluid environments.
  • It is suggested that fish larvae experience low Reynolds numbers, where viscous forces dominate, leading to limited swimming activities and reliance on water currents.
  • As fish grow and swim faster, they transition to high Reynolds numbers, where inertial forces dominate, prompting questions about the nature of these inertial forces and their relationship to water dynamics.
  • One participant provides a technical explanation of inertial and viscous forces, noting that inertial forces increase with the square of velocity while viscous forces increase linearly with velocity.
  • Another participant raises a question about the behavior of fish larvae in static versus dynamic water, pondering whether Reynolds numbers differ based on the water's motion.
  • There is a discussion about the dual nature of biofluid mechanics, addressing both external fluid flow around organisms and internal fluid dynamics within organisms.
Participants express various viewpoints and questions regarding the implications of Reynolds number, with no consensus reached on certain aspects, particularly regarding the behavior of fish larvae in different fluid conditions and the interpretation of inertial forces.
Some participants highlight the complexity of applying the same Reynolds number formula to both external and internal fluid flows, indicating potential limitations in understanding the underlying principles.
vetenar
Recently I read an article that relates fish larval survival to Reynolds number. It is a new and very interesting concept to me.
After some researching, the definition "ratio of inertial forces to viscous forces" still confuses me. As I understand it, both are resistant while the former to change in flow velocity, and the later to shape of the fluid. But in the case of an object immersed in a fluid (such as fish in water), are we still describing the forces in terms of the fluids?
For example, it is suggested that fish larvae have limited swimming activities and mainly drift with currents, therefore experiencing environments at low Reynolds number (viscous forces dominate).
As they grow, they swim much faster and independently of current (high Reynolds number; inertial forces dominate).
This is how I understand it: low Reynolds number means larvae will experience more viscous forces from the water, so as they move with the water current, a coat of water will cover their surface skin (feeling like a drag).
What I do not understand is when at high Reynolds number as for adult fish; swimming velocity is proportional to Reynolds number, and so to inertial forces. Do these inertial forces refer to that of water? But how can the inertial forces of water increase? Is it a result of the faster swimming of the fish - that it swims through a greater volume of water and so must experience more inertia?
By inertial forces, we mean momentum per unit volume, ##\rho v^2## where ##\rho## is the water density. Viscous forces per unit volume are proportional to ##\mu v/D##, where ##\mu## is the water viscosity and D is a nominal "diameter" of the object. The Reynolds number is the ratio of these quantities. So both quantities increase with velocity, but inertial increases with the square of object velocity (relative to the surrounding water), while viscous forces increase with velocity to the first power. And, the ratio is proportional to the diameter of the object, so the bigger the object, the higher the ratio. So Reynolds number increases both in proportion to the velocity of the object (relative to the surrounding water) and to its diameter.
The preview chapter of this book describes how biofluid mechanics can be either about fluid flow around the organism (air flow around a bird or water flow around a fish, etc.) or about fluid flowing inside it (like the blood circulation in veins and arteries).
https://link.springer.com/chapter/10.1007/0-387-21803-3_13
hutchphd said:
Here is a nice explanation of "Life at Low Reynolds Number" by a very good physicist. Worth a look.
Thanks so much for the link. It was very fun to read and leads to many interesting references. Now I see when we talk about low Reynolds number, viscosity plays a big part.
I have the fortune to have organisms of size ranging from 10 ##\mu m## to 1 cm. This makes me really think about how and why they swim the way they do in the water.
Thank you for the clear explanation. Their relationships make more sense to me now.
Another question comes into mind. Reynolds number is about the object velocity relative to water. But fish larvae behave differently when the water is at rest or in motion; they swim to avoid sinking to the bottom. When water is at rest, the larvae have to spend more time and energy on swimming. When water is in circular motion at a certain velocity in the tank, they are generally carried by water passively and occasionally make some feeding movements on their way. In this sense, do the larvae in static water have higher Reynolds numbers than those in dynamic water?
Thank you for the source. It is exactly these two situations - flows past objects and internal flows (in pipe or in circulation) - which I find confusing. It is unclear to me how both of them can be described by the same formula. I may be missing something fundamental.
  • · Replies 17 ·
9K
16K
