Relative Humidity (RH) affecting atmospheric attenuation of light?
In summary, the difference in atmospheric attenuation between SC and AZ would likely be negligible due to the increased amount of water vapour in the air at 50% RH.
sistruguru
Ok, so I have another question that online searches have not been able to produce. Everything I've seen online references sound waves, or RF signals, or electromagnetic waves. I know that the reason we can view sunsets and sunrises safely is because of atmospheric attenuation - the amount of "material" (water vapor, pollution, topography, foliage, etc), and of course the more oblique, the more substance there is for the light to travel - but I'm trying to find a publication that can tease out how relative humidity (alone) impacts the degree of atmospheric attenuation. Let's say we are comparing a sunset/sunrise in Arizona with 15% RH, compared to a sunset/sunrise with 90% RH in SC. How much of an impact does that added amount of humidity have? To go with extremes, to make it easy, let's just compare an RH of 0% to an RH of 100%.
As always, any insight helps.
Science news on Phys.org
Just so no one thinks the difference might be negligible, I'm doing this in reference to moonlight, at moonrise/ moonset, with the various phases of the moon. Of course a full moon would be the easiest to envision. So the question would be, on the night of a full moon, when the moon is at 170 degrees to the horizon, in an environment with 100% humidity, compared to a full moon at 170 degrees to the horizon with 0% humidity, would the amount of lux vary? And let's consider both locations to be of reasonable distance from any sources of air pollution. And both are nearly flat, so minimal interference from topography or foliage.
^that first link seemed to be mostly concentrated around electromagnetic waves, correct? It only mentions light a couple of times in the article.
I used your search string and came up with several new pubs I had not seen. I'll dig through those. Most seem to be dancing around the immediate question, but I suppose that is to be expected. Perhaps it is just a more involved answer.
But light is electromagnetic waves. It differs from radio only by frequency.
Even within the visible spectrum, the answer for red light may be different than green, and different than blue.
Good luck digging. You're sure to learn something interesting.
Likes davenn and sistruguru
I'd be surprised if relative humidity was the key factor, unless it was so high that mist was starting to form. I think you should be asking about absolute humidity--the actual amount of water vapour in the air.
Edit: There's about twice as much water vapour in the air at 50% RH and room temperature, than at 100% RH and the freezing point.
Likes sistruguru
Interesting, thanks for that suggestion. I'll look more into that
1) What is relative humidity?
Relative humidity (RH) is a measure of the amount of water vapor present in the air compared to the maximum amount of water vapor that the air can hold at a given temperature. It is expressed as a percentage.
2) How does relative humidity affect the atmospheric attenuation of light?
Water vapor in the air can absorb and scatter light, causing it to be attenuated (reduced in intensity). The higher the relative humidity, the more water vapor in the air and the greater the attenuation of light.
3) Why does relative humidity affect the atmospheric attenuation of light?
Water molecules in the air can absorb and scatter light due to their dipole moment, which means they have a positive and negative charge. This causes them to interact with the electromagnetic fields of light waves, leading to attenuation.
4) How does relative humidity vary with altitude?
The relative humidity typically decreases with increasing altitude. This is because colder air at higher altitudes can hold less water vapor, so the same amount of water vapor will result in a higher relative humidity at lower altitudes.
5) Can relative humidity affect different wavelengths of light differently?
Yes, different wavelengths of light can be affected differently by relative humidity. This is because water vapor absorbs and scatters light more strongly at certain wavelengths, such as infrared and ultraviolet, compared to visible light.
  • Other Physics Topics
