Ricci tensor of the orthogonal space
PLuz
While reading this article I got stuck with Eq.(54). I've been trying to derive it but I can't get their result. I believe my problem is in understanding their hints. They say that they get the result from the Gauss embedding equation and the Ricci identities for the 4-velocity, u^a. Is the Gauss equation they refer the one in the wiki article?
Looking at the terms that appear in their equation it looks like the Raychaudhuri equation is to be used in the derivation in order to get the density and the cosmological constant, but even though I realize this I can't really get their result.
Can anyone point me in the right direction?
Thank you very much
Note:The reason why I'm trying so hard to prove their result is because I wanted to know if it would still be valid if the orthogonal space were 2 dimensional (aside some constants). It appears to be the case but to be sure I needed to be able to prove it.
Yes, the Gauss equation that they're referring to is the same Gauss equation mentioned in the Wikipedia article, relating the Riemann tensor of a surface to its second fundamental form. The second fundamental form, in turn, describes the embedding of the surface and can be expressed in terms of the kinematics of the normal congruence.
If you haven't already, I suggest you look up the cited articles, refs 5 and 6 by Ehlers and Ellis, where this relationship is proved.
I agree with Bill. This kind of "legwork" should be almost second nature. Another place to look is section 6.3 "The other Einstein field equations" in the new book "Relativistic Cosmology" by Ellis, Maartens, and MacCallum,
http://www.physicstoday.org/resource/1/phtoad/v66/i4/p54_s1
I just saw my error. I was forgetting some terms and in the end the expressions were obviously different. Thank you for the references, I had taken a quick look at them but, clearly, I had to read them with more attention...
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
