MHB Richardson's Extrapolation for Derivative Estimation
  • Thread starter Thread starter CaptainBlack
    Extrapolation
Richardson's extrapolation is applied to estimate the first derivative of the function y=(x^3)sinx at x=2 using centered difference schemes with step sizes h1=0.5 and h2=0.25. The central difference estimates yield approximately 7.17838 for h=0.5 and 7.48111 for h=0.25. Using Richardson's formula, the extrapolated derivative is calculated to be approximately 7.58202. The actual derivative value can be compared to assess the percentage error. This method effectively improves derivative estimates by reducing error through extrapolation.
CaptainBlack
From Randy Blythe's Yahoo Answers Question:
Use Richardson’s extrapolation, using a centred difference scheme for the initial estimates, to estimate the first derivative of y=(x^3)sinx at x=2 with step sizes h1=0.5 and h2=0.25. Calculate the actual derivative and the percentage error
Mathematics news on Phys.org
First you need to find the central difference estimate of \(y'(2)\) with \(h=0.5\) and \(h=0.25\).
As the central difference estimate of the derivative at \(x\) with step size \(h\) is:
\[y'_h(x)= \frac{y(x+h/2)-y(x-h/2)}{h}\]
we heve
\[y'_{0.5}(2) = \frac{ y(2+0.25) - y(2-0.25) }{ 0.5} \approx 7.17838 \]
and
\[y'_{0.25}(2) = \frac{ y(2+0.125) - y(2-0.125) }{ 0.25} \approx 7.48111 \]Now we know that the central differences approximation for the derivative is or order \(h^2\), so our Richardson extrapolation \(y'_R(x)\) for \(\lim_{h\to 0} y'_h(x)\) is:
\[y'_R(x)= \frac{ 2^n y'_{h/2}(x) - y'_{h}(x) }{ 2^n-1 } \]
with \(n=2\).
Hence:
\[ y'_R(2) = \frac{ 2^2 y'_{0.25}(2) - y'_{0.5}(2) }{ 2^2-1 } \approx 7.58202\]
I will leave the last part, the comparison with the true value to you.
CB
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
