MHB Answer to Student's Question on Right Angle Triangle
  • Thread starter Thread starter roni1
    Angle Triangle
In a right angle triangle, one angle measures 90 degrees, which is the defining characteristic of this type of triangle. The sum of all interior angles in any triangle is always 180 degrees. Therefore, with one angle at 90 degrees, the remaining two angles must sum to 90 degrees. This means each of the other angles must be greater than 0 degrees and less than 90 degrees. Consequently, no angle in a right triangle can exceed 90 degrees.
roni1
A student ask me the question:
Why the other angles in Right angle triangle can't be more than 90 degrees?
I want to answer him correctly to the question, What Should I Say to Him?
Mathematics news on Phys.org
The sum of the interior angles in a triangle is $180^{\circ}$. Given that one angle is $90^{\circ}$ this leaves $90^{\circ}$ for the sum of the other two angles, which means that for either of the other angles, they must be greater than $0^{\circ}$ and less than $90^{\circ}$.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
