Risks of explosion mixing O2 and H2 in Ar magnetron plasma?
In a discussion about the simultaneous introduction of O2 and H2 in a magnetron sputtering discharge ignited in argon at low pressure, concerns were raised regarding the potential for explosions due to the presence of these gases. Participants emphasized the importance of calculating the energy released from the reaction of hydrogen and oxygen, comparing it to the energy input from the RF generator. It was suggested that a simple calculation of reaction enthalpy based on the number of moles could indicate any explosion risk, particularly since the experiment is conducted in a vacuum with a sturdy chamber. The role of the applied potential across the tungsten target and the flow rates of the gases were also discussed, highlighting that proper tuning of the plasma could minimize recombination of ions. It was noted that explosions are unlikely unless excessive gas is introduced into the system.
atomica68
I am interested in adding simultaneously O2 and H2 in a magnetron sputtering discharge ignited in Ar at a pressure of 3*10-2 mbar. The discharge is driven by a RF generator (13.56 MHz, 60 - 120W). The target is W. Can anyone told me if I can expect at any explsion to apear due to simultanoously presence of O2 and H2 in the discharge?
Thank you in advance for responses.
Chemistry news on Phys.org
I think you can figure this out yourself. How much energy would be released if all of the H2 and O2 in your experiment reacted? How does this compare with the amount of energy going into the experiment from the RF generator?
Exactly my thought - simple calculation of reaction enthalpy given number of moles of the substance should tell you if there is any risk involved. Especially taking into account you work in vacuum, so the chamber must be quite sturdy.
What is the potential applied across the tungsten and the plasma? Also, what is the flow rate of the two gasses? I work with ICPMS and have experience dealing with argon plasma ionization, but ours is at 1500W (~10,000 K) and potentials of 5 - 10V. The hydrogen and oxygen should ionize instantly going into the plasma. They will want to recombine afterwards as one would expect, but if the potential is high enough, you may accelerate the ions fast enough to hit the target before then. The concept is the same with ICPMS where the ions are accelerated and focused with lenses to prevent recombination. Typically, when tuning a plasma to produce less recombination, a lower flow rate is used. Explosion is not typically seen unless too much gas is being pumped in.
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
