Rocket moving away from the Earth
38 replies · 5K views
Frostman
A rocket of rest length ##l_0## moves away from the Earth with constant speed ##v##. A light signal sent from Earth is reflected by mirrors placed one on the tail and one on the head of the rocket. The first reflected signal returns to the transmitting station after a terrestrial time interval ##T##, while the second reflected signal arrives with a delay of ##\Delta T## compared to the first. Based on this information, determine the rocket's distance from Earth at the moment of receiving the first signal and its speed of departure.
Time dilation and length contraction
I first began to identify the various events in the problem. I call the rocket ##S'## and the Earth ##S##.
  1. Sending signal
  2. Tail signal reflection
  3. Head signal reflection
  4. Tail signal return
  5. Head signal return
For the Earth I know that:
##t_4 = T##
##t_5 = T + \Delta T##
Since the two events occur at the same spatial point for ##S##, ##S'## will observe a dilation of the time interval.
##\Delta T_{54} = \Delta T##
##\Delta T_{54}' = \gamma \Delta T_{54}=\gamma \Delta T##
Furthermore, ##S## sees the rocket contracted by a gamma factor.
##l=\frac {l_0} \gamma##
By identifying with ##d## the distance traveled by the rocket we can write that (##c=1##):
##t_2=\frac d {1-v}##
##t_3=\frac {d+\frac {l_0} \gamma}{1-v}##
But I can't go beyond these considerations to find the two requests ...
PeroK said:
Why not focus on the ##\Delta T## first? What does ##\Delta T## depend on?
It depends on the time that the signal from the tail arrives on Earth (##t_4##) and on the time that the signal from the head arrives on Earth (##t_5##).
So if the tail-to-ground distance at instant ##t_4## is ##x##, the distance that the head-to-ground signal must travel is ##x + \frac {l_0} \gamma##. Right?
So:
##\Delta T = \frac {\frac {l_0} \gamma}1##
PeroK said:
PS finding the distance should be easy, so I'm not sure why there's a problem there.
If ##t_4=T##, then the distance should be: ##d=(1-v)T##, where ##v## is the speed of the rocket, right?
This makes no sense.
I assume they are asking for the distance to the rocket when the signal is received back on Earth. The questions are:
1) How far is the rocket when the first signal reaches the rocket?
2) How far is the rocket when the first signal is received back on Earth?
This is elementary kinematics.
So:
You're missing the obvious here: ##\Delta T## is the time it takes the second signal to go from the first mirror to the second mirror, then back to where the first mirror was.
That's the extra journey that the second signal takes.
##x_1 = (1-v)t_2##
Because as the signal reaches the mirror, the rocket moves.
PeroK said:
2) How far is the rocket when the first signal is receiced back on Earth?
##x_2 = 1t_4=T##
But I need to fine ##t_2## so
PeroK said:
No. ##x_1 = ct_2##
Because ##t_2## already take into account the extra time the rocket has moved?
PeroK said:
And ##t_2 = T/2##, right? Is that not clear?
Because it takes the same time to come and go?
##T## does not directly depend on the speed of the rocket. It simply tells you how far the rocket is at a point in time. You're not told how long the rocket has already been gone.
And, yes, the light is just bouncing back off a mirror. It must be the same time there and back.
We have:
##t_1=0##
##t_2=\frac T 2##
##t_3=\frac {T+\Delta T} 2##
##t_4=T##
##t_5=T+\Delta T##
So the rocket's distance from Earth at the moment of receiving the first signal is:
##d=\frac T 2 + T = \frac 32 T##
Now I need to find the speed of the rocket. I suppose to extract this information by ##\gamma## in some time dilation or length contraction. I have those times for ##S##. I have the proper length ##l_0##.
If I measure the distance between the two mirror for ##S##, can I use it as a measure of the length of the rocket? Or probably will be more long than it should be, because the mirror in the head is going on?
Frostman said:
We have:
##t_1=0##
##t_2=\frac T 2##
##t_4=T##
##t_5=T+\Delta T##
No. You're not thinking clearly about this problem.
It's hard to help if you make so many basic errors.
Perhaps you should work through the problem with a given ##v = \frac 1 2 c##, say, and some initial distance from Earth: ##10## light-seconds, say. Then, work through the problem, calculating ##T## and the distance of the ship from Earth when the first signal arrives. Do the first part first. Leave the second mirror until you have formed a correct idea about what is happening.
Note: the first part is simple kinematics - you don't need to worry about SR.
I try to describe the situation:
The rocket leaves the Earth at a time ##t_1 = t_1' = 0##.
At a certain moment that we do not know the Earth sends a signal.
This signal arrives on the mirror present on the tail of the rocket at a time ##t_2##.
When this signal returns to earth, it returns to a time ##t_4=T##.
Since it is reflected by a mirror, the outward time ## t_2 ## is half of the total time spent in the return, so ##t_2 = \frac T 2##.
Can we agree on this first part?
Frostman said:
The round trip time for a light signal to the rocket is ##T##.
Since it is reflected by a mirror, the outward time and return times are both ##T/2##.
I'd agree with that.
You need to try with the example data I gave. You need to find some way to understand this and working an example is the obvious way.
When the first signal starts, the rocket is at a distance of 10 light-seconds, to which we add the distance to get from the Earth to the mirror and from the mirror to the earth, i.e.:
##d = 10 \text{ light-seconds} + c\frac T2 + c\frac T2##
That's wrong. And, you haven't even tried to calculate ##T##.
This is hard work!
Let me show you the answer to this. But, after that you have to start thinking for yourself.
We let ##t = 0## when the signal is sent:
The signal is at position ##ct## and the ship at position ##10cs + vt##.
We then equate the two: ##ct = 10cs + vt## gives ##t = \frac{10cs}{c - v} = 20s##.
The signal reaches the ship after ##20s## and so ##T = 40s##.
Where is the ship at ##t = 40s##?
We have ##d = 10 cs + \frac 1 2 c (40s) = 30 cs##.
The ship is ##30## light seconds away when the signal returns to Earth.
Finally, how does that relate to ##T## and ##v##?
When the signal reaches the ship, it was a distance ##d_1 = \frac{cT}{2}## from Earth.
And, when the signal arrived back on Earth, the ship was ##d = d_1 + \frac{vT}{2} = \frac{cT}{2} + \frac{vT}{2}##.
That gives us a formula: $$d = \frac{(c+v)T}{2}$$ And, we can check that works in this example: ## d = \frac{3cT}{4} = 30 cs##. Which is correct.
But, now it's up to you.
In other words, that should have been: $$d = 10 \text{ light-seconds} + c\frac T2 + v\frac T2$$
This is hard work!
Okay, what I did is really stupid. I calculated the path of the light signal, not the distance covered by the rocket.
The equations of motion are:
##x_L = ct##
##x_R = x_{0R} + vt##
So when the light signal reaches the rocket we are at a distance
##d_1 = x_L = x_R##
##d_1 = \frac{cT}2 ##
So when the light signal returns to Earth the rocket has traveled a distance
##d_2 = x_R(T)-x_R(\frac T2) = \frac{vT}2 ##
Finally we have:
##d = d_1 + d_2 = \frac{(c+v)T}{2}##
I know that I have repeated what you have written, but I have tried to elaborate considering precisely the equations of motion and times that are considered.
The point is that I considered the distance traveled by the light.
Now I need to find the speed of this rocket ##v##.
If I want to use length contraction by knowing the proper length ##l_0## I should find what ##S## sees. What we have is some times.
- The rocket takes a time equal to ##\Delta T' = \frac {l_0} v## to cover the tail-head section.
- While the light takes a time equal to ##\Delta T = c \frac {l_0} {\gamma}## to cover that stretch.
Could this be correct reasoning? I am not convinced of the second point, but perhaps it is due to the same problem as before.
First, everything is in the Earth frame, so there is no need to involve the rocket frame. The only relevance of SR is length contraction of the rocket.
Second, this is a similar kinematic problem to before: light reflecting off a receding mirror.
Okay, then if I don't consider primed quantities. I can write that the difference in time between the tailed signal and the head signal is given by this reason: the head signal travels farther than the tailed one.
For ##c=1##
##\frac {\Delta T} 2 = \frac {l_0} {\gamma} = \sqrt{1-v^2}{l_0} ##
##v= \frac{\sqrt(l_0^2-{\frac {\Delta T} 2}^2)}{l_0}##
  • Skeptical
Oh, again
##v\frac {\Delta T} 2 = \frac {l_0} {\gamma} = \sqrt{1-v^2}{l_0} ##
##v=\frac{l_0}{\sqrt({\frac {\Delta T} 2}^2 + {l_0}^2)}##
I mixing every time. I should take the time of signal and value it for the rocket.
  • Skeptical
PeroK said:
Not even close. Try ##v \approx 0##.
For ##v \approx 0## I find:
##v\frac {\Delta T} 2 = \frac {l_0} {\gamma} = \sqrt{1-v^2}{l_0} = (1-\frac 12 v^2 + o(v^2))l_0 \approx l_0##
You were supposed to see for yourself that that is a nonsensical answer.
I must be honest, this doesn't seem like a productive use of time. We have 26 posts and you have not posted anything worthwhile. You need to think about how you want to use this forum.
I want to try to understand these exercises where events appear, I have a lot of difficulty in carrying out this type of exercises, once the events have been identified I have problems managing this information.
I am looking for help in this forum to chew these exercises better and find a correct approach to follow.
I'm not only interested in passing the exam, but taking home solid knowledge and skills.
All the more so if I want to start a PhD course in theoretical physics at the end of the year.
Honestly, I don't even like that it's a passive thing, in fact it's something that bothers me a lot.
You asked me to evaluate the case where the velocity is close to zero, what I conclude is that the length seen by ##S## and ##S'## coincides, as it should be.
Well, okay, but you are misunderstanding basic kinematics to the point where the only way you get the answer is for me to do all the calculations with no contribution from you at all.
I'll put a note on the advisor's forum to see whether someone else can help, as I'm out of ideas.
I try to follow the approach to the problem a bit, assuming that obviously I don't want the solution.
You told me not to consider the rocket's primate quantities. So all ##\Delta T'##, ##T'##, ...
What I'm trying to find is the speed of the rocket.
What do I have available?
- I know the proper length ##l_0##.
- I know that the time interval between the return of the first and second signal is ##\Delta T##.
- I know that the first signal comes back to Earth after a time of ##T##.
- I know that the second signal comes back to Earth after a time of ##T + \Delta T##.
- While the reflection time interval is equal to ##\frac{\Delta T}2##
- The light signal obviously moves at speed ##1##.
For the contraction of the lengths we have that the Earth measures:
##l = \frac{l_0}{\gamma}=l_0 \sqrt{1-v^2}##
I have to find ##l##. The interval between the two signals reflections is ##\frac{\Delta T} 2##.
Is it correct to use the distance traveled by the rocket in this time interval as a length? Or is it just a measure of how far the rocket has moved and has nothing to do with the length of the rocket according to earth?
