Rocket travels along parabolic path (RECTANGULAR COMPONENTS)
7 replies · 10K views
patflo
When a rocket reaches an altitude of 40m it begins to travel along the parabolic path (y-40)^2=160x, where the coordinates are measured in meters. If the component of velocity in the vertical direction is constant at vy=180m\s, determine the magnitudes of the rockets velocity and acceleration when it reaches an altitude of 80m.
position: r=x*i+y*j (where i and j are the unitvector)
velocity: v=dr\dt
acc: a=dv\dt
lets say i tried for about 4 hours to get a concept to solve this. :(
first i put in in the equation for the motion path for y=80 to get x=10
second: position vector for point A (x=0,y=40) and point B (x=10 y=80)
third: to get the distance betwee A and B i subtract the 2 position vectors.
fourth: v=dr\dt to get the velocity
mazbe its the wrong way because the answer should be v=201 m\s and mines was 254 m\s.
i don't know where my mistake is...is the way of thinking right?
I don't how you found out dr/dt without separating out the equations for motion on x,y-axes w.r.t time from the trajectory equation.
Velocity on y-axis is constant so y=180t.
Put in trajectory eqn. to eliminate y then differentiate w.r.t. x. This will be velocity on x-axis. Add vectorially for complete velocity.
Or you could directly differentiate the trajectory equation w.r.t time. dy/dt is known, dx/dt can be found out and then added vectorially.
velocity: v=dr\dt
acc: a=dv\dt
Notice that eqn#2 has a variable in it that is defined in eqn#1. If you plug this definition from #1 into #2, what equation do you get for the velocity?
ok i tried out this:
d/dt (y-40)²=d/dt 160x
=> dx/dt=405t-90
v=vx*i+vy*j
v=(405t-90)*i+180j
but how can i find the magnitude? since in the equation for v there is still the variable "t".
Can you now find out how much time it takes for the projectile to reach a height of 80m?
may answer would be:
for the equation of path i put in y=180t and x=10 (when y=80 x=10)
then i get a quadratic function in t.
the result for t= 0.4s
i put that in v and get v=72i+180j
for magnitude: v=193,7 m/s
but as result there should be 201 m/s
t=(distance on y-axis)/(Speed on y-axis)
This is 40/180=0.22s.
