What is the role of roll damping coefficient in aircraft performance?
The roll damping derivative quantifies the change in rolling moment coefficient relative to the roll rate and is typically negative. A higher roll damping derivative indicates greater resistance to roll, which is characteristic of gliders that are designed for stability rather than maneuverability. In contrast, aircraft like the FA-18 fighter have a lower roll damping coefficient, allowing for agile evasive maneuvers. Understanding this concept is crucial for analyzing aircraft performance and stability. The provided resources offer further clarification on the topic.
btbam91
Hello, I am new to Aerodynamics and am having trouble understanding what exactly the roll damping derivative is.
The roll damping derivative is a measure of the change in rolling moment coefficient with respect to nondimensional roll rate and is usually negative.
Does that mean a glider (which isn't expected to roll) has a really high roll damping derivative where an FA-18 fighter has a lower roll damping coefficient so that it can perform evasive maneuvers?
Thanks a lot!
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
