Roller coaster friction problem?
The discussion revolves around calculating the minimum coefficient of friction required to prevent falling off a spinning ride called the "Barrel of Fun." The ride operates as a vertical cylinder, and the problem involves determining the necessary friction after the floor drops out. Participants agree that finding the rotational velocity and converting it to acceleration is essential for solving the problem. One user calculated a coefficient of friction of 658.69, prompting a request for clarification on the calculation process. The conversation highlights the challenges students face with complex problems that exceed classroom instruction.
bohobelle
You're at the amusement park and your friend wants to go on the "Barrel of Fun," where the ride is a cylinder with a vertical axis. You stand against the wall and after the ride is spinning fast enough, the floor drops out beneath you. What is the minimum coefficient of friction necessary to keep you from falling down once the floor is gone? The ride takes two seconds per revolution.
Moment of intertia of a cylinder = MR^2
I honestly have no idea what I'm doing! My teacher tends to teach us one lesson in class and then give us a ridiculously complicated problem that we are not prepared to do for homework.
I think that you need to find rotational velocity and then transform that into acceleration, and then find friction from that, but I am not sure?
Your thinking is correct.
How would I get from acceleration to friction?
I got 658.69 as the coefficient of friction, does this seem correct?
Explain how you got that.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
