Proving at Most One Real Root of x³-15x+C in [-2,2]
  • Thread starter Thread starter alexk307
    Root
alexk307
Show that the equation x3-15x+C=0 has at most one real root in [-2,2]
Rolle's Theorem, and Intermediate Value Theorem.
I showed that there is a root in [-2,2] by use of Intermediate Value Theorem.
f(-2)<0
f(2)>0
But then to show there is not two roots, I tried to use Rolle's theorem which says that if f'(x)=0 then there must be two points f(a)=f(b). I found that f'(x)=0 at sqrt(5). Which I then tried to plug back in the original function in hopes that this point would lie above the x axis, therefore it wouldn't cross the x-axis twice. But because of the C I cannot prove this because I can always make C smaller and smaller in order to make f(sqrt(5))<0.
Rolle's theorem tells us that any function which is continuous on [a,b], differentiable on ]a,b[ and has the property that f(a)=f(b), must have a c such that f&#039;(c)=0.
Now, assume that f(x)=x3-15x+C has two roots a and b in [-2,2]. Then f(a)=f(b). So what does Rolle's theorem yield?
oh! okay so that sqrt(5) is beyond the interval therefore proving that there is only one root in [-2,2].
Thank you
correct!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
