Using the root test find whether the series converges or diverges
In summary, the conversation discusses finding whether a series converges or diverges using the root test and the use of L'Hospital's Rule to solve for the limit. The conversation also mentions the potential use of the ratio test and questions about the answer being 1.
mattmannmf
172
Using the root test find whether the series converges or diverges:
Lim Sin (4/(3n+3)) / Sin (4/(3n))
n-> inf.
I have no idea how to cancel out the sin terms
It looks like you may need to use L'Hospital's Rule since you have 0/0. Do you know if the answer is 1?
n-> inf.
Why would you want to use the root test? It looks like you're using the ratio test. As Dustinfls suggests, this one looks ripe for L'Hopital's Rule.
Related to Using the root test find whether the series converges or diverges
What is the root test?
The root test is a method used to determine if a series converges or diverges by examining the limit of the nth root of the absolute value of the terms in the series.
How do you use the root test to determine convergence or divergence?
To use the root test, you take the nth root of the absolute value of each term in the series and then take the limit as n approaches infinity. If the limit is less than 1, the series converges. If the limit is greater than 1, the series diverges. If the limit is equal to 1, the test is inconclusive.
What type of series is the root test most useful for?
The root test is most useful for series with positive terms, including series with alternating signs.
Can the root test be used for all series?
No, the root test can only be used for series with non-negative terms. It cannot be used for series with negative terms or series with alternating signs.
What is the difference between the root test and the ratio test?
Both the root test and the ratio test are used to determine the convergence or divergence of a series. The main difference is that the root test uses the nth root of the terms while the ratio test uses the ratio of consecutive terms. The root test is often easier to use for series with alternating signs, while the ratio test is more useful for series with factorial terms.
