- 16,138
- 9,329
Can you not calculate ##I_O## separately for each of the three parts of the system? Then, $$I_O^{\text{(system)}}=I_O^{\text{(2m)}}+I_O^{\text{(m)}}+I_O^{\text{(ring)}}.$$
What is ioring herekuruman said:Can you not calculate ##I_O## separately for each of the three parts of the system? Then, $$I_O^{\text{(system)}}=I_O^{\text{(2m)}}+I_O^{\text{(m)}}+I_O^{\text{(ring)}}.$$
It is the moment of inertia of the ring about bottom point O. Use the parallel axes theorem to find it.palaphys said:What is ioring here
Draw a FBD of the entire system. Put in all the forces and then apply Newton's second law in the vertical and horizontal direction.palaphys said:Sorry for asking but could u pls tell how to do the next part? Just say by words, I will find out the equatiosn
Pls say direction of frictionkuruman said:It is the moment of inertia of the ring about bottom point O. Use the parallel axes theorem to find it.
Sorry don't get you, i thought friction opposed relative sliding and I gotta see which direction sliding would take place..Lnewqban said:If the ring were horizontally floating on a frictionless surface it would only rotate around a fixed vertical axis.
Use the third law of Newton to figure the direction.
You mean fbd of cm?kuruman said:It is the moment of inertia of the ring about bottom point O. Use the parallel axes theorem to find it.
In order to move in a straight line, the ring needs to have a point of support on which exert a force to impulse its center of mass linearly.palaphys said:Sorry don't get you, i thought friction opposed relative sliding and I gotta see which direction sliding would take place..
The center of mass is a geometrical point on which only gravity acts. You need a FBD in which you can put the forces that you need to find, friction and the normal force. What do you think you should draw a FBD of?palaphys said:You mean fbd of cm?
Center of mass the 5m thing?kuruman said:The center of mass is a geometrical point on which only gravity acts. You need a FBD in which you can put the forces that you need to find, friction and the normal force. What do you think you should draw a FBD of?
But isn't the center of mass accelerating tangentially as well here? Pls help. What else to draw fbd of?kuruman said:The center of mass is a geometrical point on which only gravity acts. You need a FBD in which you can put the forces that you need to find, friction and the normal force. What do you think you should draw a FBD of?
Consider this related question. You are at rest standing up and at some point you start walking forward. Clearly, you accelerate because your velocity changes from zero to a non-zero value. What force provides this acceleration? In what direction is it?palaphys said:Sorry don't get you, i thought friction opposed relative sliding and I gotta see which direction sliding would take place..
Frictional force forward?kuruman said:Consider this related question. You are at rest standing up and at some point you start walking forward. Clearly, you accelerate because your velocity changes from zero to a non-zero value. What force provides this acceleration? In what direction is it?
Only torques provide angular acceleration.palaphys said:But the what force is providing angular acceleration for fring? If it's friction, isn't it retarding the rotation?
Yes. Do you think that there is a frictional force here? Why or why not?palaphys said:Frictional force forward?
Friction here is static right? It is only ensuring the condition for pure rollingkuruman said:Yes. Do you think that there is a frictional force here? Why or why not?
I meant the torque due to frictionkuruman said:Only torques provide angular acceleration.
About what point? About point O it's zero.palaphys said:I meant the torque due to friction
Right. In what direction does it point?palaphys said:Friction here is static right? It is only ensuring the condition for pure rolling
About center of masskuruman said:About what point? About point O it's zero.
Are you asking me or are you telling me? Reason it out.palaphys said:Static friction points forward? Yes? No?
Have you seen bicycles with reflectors on the spokes of their wheels? Imagine a reflector at distance ##\frac{1}{5}R## from the axis of the wheel. The path that it describes as the bicycle moves forward is a cycloid. That's the path of the CM here.palaphys said:i cannot think about how the center of mass is moving here
Please, stop and think about the excellent reasoning led by Kuruman.palaphys said:About center of mass
Static friction points forward? Yes? No? I think so because the center of mass is probably accelerating forward.. i cannot think about how the center of mass is moving here.
Ok. I assume cycloid is some kind of curvilinear motion. Now in GENERAL rolling cases, where the center of mass is the geometric center, it just goes in a straight line right?. So I feel that the center of mass here may have two accelerations, namely linear and tangential. Am I right?kuruman said:Are you asking me or are you telling me? Reason it out.
a)the weels will slide and not sure if I would moveSteve4Physics said:May I throw-in a couple of questions for @palaphys ?
a) You are in your new Porsche , stationary, on level ground. . The ground is super slippery – negligible friction between the ground and the wheels. What happens when you try to accelerate?
b) What happens if there is friction (e.g. if the ground is dry concrete)?
The centre of mass of an object will only accelerate when a net force acts on the object. What can you deduce about the type and direction of the force which makes your Porsche accelerate?
If you would draw a FBD you should be able to see that if the wheel is accelerating to the right, there is some force acting to the right. What force can act to the right? Which way is normal force. Which, direction are the weight forces, is anyone pushing the wheel etc... are questions you should be asking yourself. At the very least by process of elimination you should see that there must be a horizontal force, and where it must act.palaphys said:Oh so you are saying that here as center of mass moves forward, it is due to friction?
... and to the imbalance of masses around the ring: that is the driving torque.palaphys said:... as center of mass moves forward, it is due to friction?
But will friction not cause angular retardation if it acts towards the right? Then how will the no slip condition be maintained?erobz said:If you would draw a FBD you should be able to see that if the wheel is accelerating to the right, there is some force acting to the right. What force can act to the right? Which way is normal force. Which, direction are the weight forces, is anyone pushing the wheel etc... are questions you should be asking yourself. At the very least by process of elimination you should see that there must be a horizontal force, and where it must act.
