Trigu
- 7
- 0
I have had a thought experiment in my head for a while now and I am unable to find clear enough examples/info that deal with similar issues, to solve it on my own. This is why I hope that someone in this forum can at least point me towards a solution or provide hints as to where should I be looking to resolve this question.
The main issue I am having is how to combine the physics of rotating bodies and the motion of a larger system that the rotating body is a part of. Most of the info I am able to find about rotating bodies is in the context of rotation around a fixed axis.
Unfortunately what I am interested in requires info about bodies that rotate around an axis that is not rigidly fixed. At least not fixed as in tied to an external system etc. The axis would still be fixed to an internal system but that system has the ability to move around.
The issue:
I am interested to know, how much force a system is subjected to when a body that is in that system is pushed to rotate around an axis.
Ideally, I would like to have a formula that describes how the forces interact in this system. For example, if I know the weights and dimensions of all of the bodies in the system and the force and time it is applied to rotate the body, I would like to be able to calculate the force that is acting on the system.
I think I understand what should happen to the system in a situation like that, but I am unable to describe it with formulas. My current understanding would be that the size of the force acting on the system depends on the masses of the rotating body and the rest of the system. So when the rotating body has low mass compared to the system, the body will rotate more and the system would move less. But if the rotating body has more mass than the rest of the system, then due to the large moment of inertia of the rotating body the system acts closer to a rigid body and the body rotates less and more force is exerted on to the system. If I am misunderstanding something please let me know.
To make this easier I created a pdf that I am attaching to this post. The pdf shows the question as a thought experiment, with I hope, enough descriptions and clarifications so that someone could provide some insight.
If it is not clear enough I am more than happy to try to explain with more diagrams etc.
The issue:
