Rotational Kinematics of a disk
The discussion revolves around a problem involving the rotational kinematics of a disk that undergoes constant angular acceleration. Initially at rest, the disk moves from an angle of -90° to 130° over 3.15 seconds. Participants emphasize the need to apply rotational kinematics equations to determine the angular speed after the disk completes one full revolution back to -90°. There is a clear focus on using kinematic principles rather than dynamics to solve the problem. The solution requires calculating the angular velocity based on the given parameters and kinematic equations.
Batman4t
A disk with a radial line painted on it is mounted on an axle perpendicular to it and running through its center. It is initially at rest, with the line at q0 = -90.0°. The disk then undergoes constant angular acceleration. After accelerating for 3.15 s, the reference line has been moved part way around the circle (in a counterclockwise direction) to qf = 130°.
Given this information, what is the angular speed of the disk after it has traveled one complete revolution (when it returns to its original position at -90.0°)?
http://www.ajdesigner.com/phpcircularmotion/centripetal_acceleration_equation.php
Not sure I know have to use Rotational Kinematics to find the angular velocity first.
You have to use only the eqns of Rotational Kinematics, not dynamics.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
