Rotational Kinematics of two masses
The discussion focuses on calculating the angular acceleration of a pulley in a system with two masses connected by a string. The left mass is 9.00 kg and the right mass is 1.60 kg, with the pulley having a radius of 5.0 cm. Initial calculations led to an incorrect angular acceleration of 196 radians/second due to a sign error in the equations. After correcting the calculations, the angular acceleration was determined to be approximately 136.83 radians/second. The conversation also touches on the inconsistency of significant figures in academic settings.
tbdm
Consider a system of two masses joined by a massless string with the string passing over a massless frictionless pulley with a radius of
5.0 cm.
The mass of the left is
9.00 kg
and the mass on the right is
1.60 kg.
Find the angular acceleration of the pulley when the masses are released from rest, and in which direction the pulley is spinning. (Find the magnitude of the angular acceleration.)
F=m*a
torque = I*alpha (angular accerleation)
T=m*g-m*a
I tried getting the two tensions. T1 = (9kg)(9.8m/s^2)-(9kg)a; T2 = (1.6kg)(9.8)+(1.6kg)a
Then torque 1 - torque 2 = I*alpha, though the second part is 0 because the mass of the pulley is 0.
So I end up with Tension 1 equals tension 2 (I divided out the radius).
(9kg)(9.8m/s^2)-(9kg)a = (1.6kg)(9.8)+(1.6kg)a
This gave me a = 9.8 m/s^2. I divided it by the radius, .05 meters, to get an angular acceleration of 196 radians/second. This answer is wrong however.
hi tbdm! :smile:
nooo … it gives you 7.4(9.8) = 10.6a :wink:
(btw, you could have said the tensions were the same, since it's a continuous string, and the pulley has zero mass)
Likes 1 person
Alright, it looks like I accidently switched the sign on the 1.6a when I was working it out. So that makes the tangential acceleration ≈6.842 m/s^2, and the angular acceleration is then 136.83 radians/s^2, does that sound right?
Seems good to me. Check if you used the correct numbers, etc. The method is correct, at least!
Likes 1 person
Haha yeah, I've always found it funny that my professors tell us to use sig figs, and yet use homework programs that not only don't count them, they sometimes think the answer is wrong if you do use them. Promotes bad habits :wink:
Thank you all
Thread 'Correct statement about a reservoir with outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
