Rotational Plus Translational Motion for Sphere of Yarn
The discussion revolves around calculating the length of a string unwound from a solid sphere when it reaches an angular speed of 28.6 rad/s. The initial calculations attempted to use kinematic equations, but the role of tension in the system was highlighted as a crucial factor. It was clarified that the sphere experiences acceleration due to the tension, which is equal to its weight, leading to a net force consideration. The conservation of energy approach was suggested, where the work done on the sphere could be calculated using the formula for kinetic energy. Ultimately, dividing the work done by the tension provides a method to find the length of the unwound string, resulting in an answer of approximately 0.742 m.
sweetpete28
A massless string is wrapped around the equator of a solid sphere (mass M = 76.2 kg, radius R = 0.211 m). A girl holds the free end of the string, and the sphere is released from rest, Assume:
- the sphere is always parallel to the floor
- the string is always perpendicular to the radius of the sphere
- the string does not slip over the sphere
What is the length of the string that has been unwound when the sphere reaches an angular speed ω = 28.6 rad/s?
Can someone please help? Here is what I did but answer is wrong:
v = ωr = 6.0346 m/s
vf^2 = v0^2 + 2as
s = 1.86 m
1.86 = 1/2at^2
t= .615s
.615s * 28.6 = 17.59
17.59 * .211 = 3.7...but this wrong...please help?
hi sweetpete28! :smile:
(try using the X2 and X2 buttons just above the Reply box :wink:)
sweetpete28 said:
v = ωr = 6.0346 m/s
vf^2 = v0^2 + 2as
s = 1.86 m
you're assuming that a = g
what about the tension? :wink:
Ohhh
You're right! Tension would = mg since it does not fall...right? So there is 0 acceleration.
I know θ(t) multiplied by radius r will give me length string has been unwound...but how do I get what t equals? I'm still stuck...
If mg is tension = 748 N and work done on sphere is 555J once it reaches 28.6 rad/s angular velocity...can I divide 555J by 748N to get length unwound since F times d = Work??
Which would give answer of 555/748 = .742 m?
sweetpete28 said:
Ohhh
nooo, of course it accelerates, but at less than g
either call the tension T, and consider forces and torques,
or (probably easier) use conservation of energy :wink:
If mg is tension = 748 N and work done on sphere is 555J once it reaches 28.6 rad/s angular velocity...can I divide 555J by 748N to get length unwound since F times d = Work?? (I used KE = 1/2MIω^2 to get work done on sphere = 555J).
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
