Why is the center of mass energy linked to the parameter \mu?
  • Thread starter Thread starter physicus
    Coupling Running
physicus
My course on QFT follows Srednicki's book. He derives the running of coupling constants in different theories in the following way: When he uses dimesional regularization (going to x-\epsilon dimensions), he has to introduce a parameter \mu with dimensions of mass in oder to keep the coupling, let's call it \alpha, dimensionless. Later, the running of the coupling is determined by demanding that no measurable quantity can depend on \mu. We get a function \alpha(\mu).
Consider now a process. I want to know the coupling strength in that process. Apparently, \mu is linked to the center of mass energy of the process considered. That's how I determine the coupling. My question is now the following: Why is \mu linked to the energy scale of the process I am considering? In the derivation the magnitude of the parameter \mu is completely arbitrary. I asked my professor the same question and he answered that \mu must be linked to the center of mass energy, since this is the only parameter with dimesion of mass, that the considered process can depend on. Since ist depends on \mu and the center of mass energy, these two quantities must be linked. I do not understand that argument: Didn't we demand earlier that physical processes must be independent of the unphysical parameter \mu? So the considered process cannot depend on \mu.
I would be very thankful if someone could clear that up for me.
physicus
I think the idea is this: when you compute an amplitude for some process you will get an expression in terms of mu. You can evaluate this expression at any mu you like, as long as you choose the correct values of the coupling constants for the chosen value of mu.
However, some values of mu are better than others. In our amplitudes we generally find terms of the form ln(E/mu) where E is some typical energy scale of the process we are considering. If mu is very different from the scale E, this logarithm can be a large number. If it's large enough, it can actually start to hurt the convergence of the perturbative expansion. The presence of these large logarithms in the higher order terms can make them comparable in magnitude to the leading terms, whereas for good convergence we want the higher order terms to be much smaller than than the leading terms.
We can fix this by choosing mu to be comparable to the typical energy scales of the process we are considering. Then we have no large logarithms, and improved convergence of the perturbation series.
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
