Fortran Solving Fortran Runtime Error 112 - Mach Number Calculation
The discussion revolves around a Fortran program designed to calculate the Mach number using the bisection method. The user encountered an error in line 40 of their code. After troubleshooting, it was identified that the condition in line 10, which directed the program flow based on the value of the variable 'sucin', was incorrect. The user realized that relying solely on the bisection method was inadequate for this problem, as it required finding the extremum of the function before selecting the appropriate interval. They successfully resolved the issue by incorporating another numerical method to locate the extremum, allowing the bisection method to function correctly. The user expressed interest in finding a more elegant solution for solving the function.
Hejmore
Hi, I try to write program to calculating mach number, with using bisection method. When I run program, fortran write to me an error in line 40. Can you help? I tried to calculating function by using wolfram sucesfully but I need to run it on fortran, An equation is 1.7795 - (0.334898 (1 + 0.2 x^2)^6.)/x^2. Can you help me? Thx
My error code:
Fortran:
program mach
     real pp,z1,z2,sucin,a,b,x,machx,a1
      pp=1
      a1=0.1
      b=3
      z1=pp**2-(0.334898*(1+0.2*a1**2)**6)/a1**2
      z2=pp**2-(0.334898*(1+0.2*b**2)**6)/b**2
      sucin=z1*z2
      if(sucin.lt.0) go to 1
      if(sucin.gt.0) go to 3
    1 continue
      do
          a=a1
          a1=(b+a)/2
          sucin=z1*z2
          machx=a
          x=abs(b-a)
          if(x.lt.0.0001) exit
          if(sucin.lt.0) cycle
          if(sucin.gt.0) go to 2
      end do
    2 continue
      do
          b=a1
          a1=(b+a)/2
          z1=pp**2-(0.334898*(1+0.2*a**2)**6)/a**2
          z2=pp**2-(0.334898*(1+0.2*a1**2)**6)/a1**2
          sucin=z1*z2
          machx=b
          x=abs((b-a))
          if(sucin.gt.0) go to 1
      end do
    3 continue
      print*,'Mach number is'
      write(5,*) machx
      stop
end program mach
Technology news on Phys.org
Problem is solved.
That's great.
What was the actual error and how did you solve it?
You can see, the condition if( sucin.gt.0)go to 3 in line 10 is wrong. If I use only bisection method, the program will not work correctly, because i must to find extreme of the function and then must to choose right interval. I had to use a next numerical method to find extrem and then I could solve this problem. I would be glad if you find some more elegant solution for solving this function. Thx
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
9K
25K
