Safe nitrogen compound to decompose a 500 deg C in a furnace?
  • Thread starter Thread starter Andy Ward
    Nitrogen
A metallurgist seeks a nitrogen compound for a powder metallurgy project that can be mixed with metallic powder and heated to 500°C to liberate nitrogen for metal surface reactions. Concerns about toxicity arise with options like copper cyanide, which may release harmful fumes upon breakdown. Alternatives discussed include melamine, which is a C-N compound, and magnesium nitride powder, known for steady decomposition at the desired temperature while releasing nitrogen. Zinc nitride is also suggested as a potential option. Overall, the conversation highlights the challenge of finding a safe nitrogen source in powder metallurgy applications.
Andy Ward
Hi all - looking for help as a metallurgist - not a chemist.
For a powder metallurgy project I need a simple, solid, powdery nitrogen compound I can mix with metallic, compacted powder and heat to 500 deg C. I need it to liberate nitrogen to react with the metal surfaces. I was looking at copper cyanide but will this liberate toxic fumes on breakdown? Was also looking at such things as urea but want hydrogen-free if I can get it or the hydrogen might dissolve in my aluminium powder.
Any suggestions based on C-N materials?
Many thanks for any response.
Andy
Chemistry news on Phys.org
All CN compounds seem to produce hazardous fumes when pyrolized so "safe" is not likely in this case. If you have your heart set on a CN compound, I think melamine is your most likely candidate. C3H6N6 (or CH2N2)
You might also use magnesium nitride powder. It decomposes steadily up to 500C releasing it's nitrogen. I would think the magnesium would alloy itself with the aluminum if that can be tolerated. Might try zinc nitride as well.
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
