Is a Heightfield a Scalar or a Vector and How Many Dimensions Does it Have?
  • Thread starter Thread starter hexa
    Scalar Vector
A heightfield is classified as a scalar because it assigns a height value to each point defined by coordinates (x, y). This means that for every pair of x and y values, there is a corresponding height, making it a 2-dimensional representation in a 3-dimensional space. The confusion may arise from visualizing heightfields as vector fields, but they do not possess direction in this context. Therefore, heightfields are best understood as scalar functions describing a surface. Overall, they illustrate a 2D surface within a 3D framework.
hexa
Hello,
I've been wondering if a heightfield is a scalar or a vector, and how many dimensions in space it has.
Sure, if it's a scalar it only has a magnitude, and as a vector magnitude and direction but I cannot see either, or keep them apart in this case. Density or gravityacceleration are easier I guess.
Dimensions: 2 would work out: h=(x,y) but would 1d and 3d possible as well?
Hexa
Hello Hexa,
in the case of h=h(x,y) you get for each set of values x and y a corresponding height h, which is a scalar. Or to put it another way: For every point on the x-y-surface you get a certain height h. So altogether the function describes a 2-Dimensional surface in a 3-Dimensional space.
I hope that was helpful for you.
Hi David,
that was also my intuition. I got confused by an old exam question about visualising such heightfield as vectorfield:confused: and could not find a direction.
Thanks a lot
Hexa
DavidBektas said:
Hello Hexa,
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
